Re: swapping V4A51 for V4AW3 [Re: dannytuned] #871463 03/01/08 11:36 PM
"taps into" the tps?
Correct.
Re: swapping V4A51 for V4AW3 [Re: dannytuned] #871464 03/02/08 05:41 AM
NathanC Offline
Awesome work, and thank you for posting up! <img src="/forums/images/graemlins/kewl.gif" alt="" />
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: swapping V4A51 for V4AW3 [Re: NathanC] #871465 03/03/08 10:28 PM
dannytuned Offline OP
got a 97-99 ms service manual on ebay today. too wet and rainy here to visit a yard today, but i'll post when i have more progress. <img src="/forums/images/graemlins/cheers.gif" alt="" />
2001Sport 3.0-Headers-Cage-RoofChop-NP231/D300-D44/ARB-Ford9/Yukon/3Link-37's+H1's-PSC Assist-108:1
Re: swapping V4A51 for V4AW3 [Re: dannytuned] #871466 03/03/08 11:08 PM
NathanC Offline
Hey, I'll give you $10 for that V4AW3 tailhousing. <img src="/forums/images/graemlins/wink.gif" alt="" />
'88 Mighty Max
Re: swapping V4A51 for V4AW3 [Re: NathanC] #871467 03/03/08 11:49 PM
check pm
Re: swapping V4A51 for V4AW3 [Re: dannytuned] #871468 07/16/14 03:06 AM
Dug up this old thread for an update. The swap went smooth, and to recap here's what I needed to get the NP231 into my 2001 Sport(should be the same for all 2000-04 Montero's and Sports).
-Trans, flywheel+bolts, pilot bushing, starter, and the plate that goes between motor and trans, from a 1999 Sport.
-Transfer case adapter, and NP231 from a 2001 Cherokee.
-AW4 shift controller. I shift the trans and engage TC lock manually, and there would be a lot more involved to get the trans to shift automatically again, but I'm pretty sure it's doable(I like my switch mounted on the shift lever:D)
-I shift the 231 with a modified cable shifter from my old 91 Eclipse, and the Dana300 has twin sticks that come through the factory hole in the floor.
Here's the part I just finished. The swap caused five trouble codes, the failure of the five solenoids inside the V4A51, which is no longer in the truck, ES_97Sport did research on this for his sport and figured out that a 3ohm 50Watt resistor can be substituted for each solenoid and make the PCM happy again. See THIS thread.
I still have no speedometer but others have used a Dakota box to convert/modify the signal. I just haven't had the time or cash to tackle that project yet, need to finish the rear swaybar and get tires first.
Thanks for everyone's help, the Wire always comes through for a guy!
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: swapping V4A51 for V4AW3 [Re: dannytuned] #1103460 05/21/17 04:24 AM
Re digging up an old thread, i was thinking about how nice it would be to have a V5A51 instead of my V4AW3.
Re: swapping V4A51 for V4AW3 [Re: dannytuned] #1103463 05/21/17 07:32 PM
I have an 02 Sport AWD for parts. What trans is in this? 3.0L-24V, auto...192K miles
Re: swapping V4A51 for V4AW3 [Re: dannytuned] #1103464 05/22/17 02:43 PM
V4A51
Re: swapping V4A51 for V4AW3 [Re: TOASTY] #1103541 06/05/17 01:05 AM
ANOTHER UPDATE
The check engine light went off with Edward's 3 ohm resistor hack, but without a speedometer the EGR and EVAP self tests would not complete. So i dug around and found the speed sensor from the NP231 and it bolted in(to the D300) and plugged right in(to my 2001 Sport VSS connector). After a quick trip around the block noticing that the speedo was reading way fast, i swapped on a smaller gear from the D300(i think), and got it to within 5mph.
The self tests are all complete now and no trouble lights on the dash, my state emissions tester is happy and the Sport is street legal.
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6425 MB (Peak: 0.7670 MB) Data Comp: Off Server Time: 2026-10-24 13:12:01 UTC
