Deep water & 1988 22RE #871930 02/28/08 04:28 AM
510rcr Offline OP
I have done some searches and not found answers... Last weekend I was doing a crossing where water almost came over the hood just for an instant. Luckily I did not have a problem. I plan on making a snorkle setup so I can be more agressive but wonder about the computer brain (22RE) that is behind the passenger side kickpanel. Would that be my weak link should I be in long enough for the cab to fill? Are there techniques for sealing the kick panel brain off? Besides the normal ignition stuff, is there anything else I need to consider sealing brain wise?
Last question - does anyone have any photos where they cut their fenders for say 35's on a stock suspension? I'd like to run tall narrow tires. I want the travel but want to keep my center of gravity as low as possible.
Thanks in advance for any help.
Matt - Topeka, KS
Re: Deep water & 1988 22RE [Re: 510rcr] #871931 02/28/08 04:44 AM
4Crawler Offline
Some waterproofing ideas:
- http://www.4crawler.com/4x4/CheapTricks/WaterProofing.shtml
Some fender trimming info:
- http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml#FAQ10
Basically cut or bend anyplace the tires rub.
Re: Deep water & 1988 22RE [Re: 510rcr] #871932 02/28/08 02:03 PM
grandeyota Offline
Get a tupperware that just fits around the computer box. Cut some slits in it for the mounting brackets and a hole for the wiring. Then put the lid on and RTV all the openings that were cut. Put some of that silica get packets like they put in shoes in there to absorb any humidity trapped in there.
Fur clog in the sausage grinder
Re: Deep water & 1988 22RE [Re: grandeyota] #871933 03/02/08 05:26 AM
510rcr Offline OP
Computer has been down - Thank you to all
PHP: 7.4.33 Page Time: 0.023s Queries: 15 (0.020s) Memory: 0.6052 MB (Peak: 0.6620 MB) Data Comp: Off Server Time: 2026-11-18 11:57:44 UTC
