hi low idle #872319 02/29/08 04:47 AM
A
aljeeplover Offline OP
hello every one im a first time user here so sorry if i make a mistake. I have a 1989 jeep YJ 2.5 singel port in jection,when i start it up the idal is very low but pics up as it worms up then it idels about 900 to 1200 rpm all so under excelaration it fells like runs out of power then i have to back off the throtel to get it to pic up speed. I am at a loss i hope so one has an idea <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: hi low idle [Re: aljeeplover] #872320 02/29/08 05:22 AM
BigJim Offline
how long since a tunup?
Re: hi low idle [Re: BigJim] #872321 02/29/08 07:54 AM
A
last week i allso changed the fuel filter it was very dirty
Re: hi low idle [Re: aljeeplover] #872322 03/01/08 02:13 AM
JurassicJeep Offline
In an 89 YJ some of the things that you mentioned like changing the gas filter is one of the first things you do when you bring it home ,,, A tuneup will help but if the gas filter was that bad then you have a lot of crap in the gas lines .. I'd flush the whole system and take a good look at what comes out .. YJ's are infamous for haveing problems with their carbs because of the dirt and crap thats in the tank ... My wifes 89 4.2L with the Carter Carb was a real pain until we changed it to the Webber Carb.....You mentioned something about it haveing fuel injection which i didn't think an 89 came with unless they had it in the 4cyl. for some strange reason... and if thats true then your jets might be clogged .....
Think they'll have That on the Tour
Re: hi low idle [Re: aljeeplover] #872323 03/01/08 06:54 AM
A
ya im sorry idid not say that it was a 4 cylinder ,i ran the pump and the fuel lines are clean . Is it posabel it could be the tps ?
Re: hi low idle [Re: aljeeplover] #872324 03/01/08 07:04 AM
BigJim Offline
Yep!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6072 MB (Peak: 0.6763 MB) Data Comp: Off Server Time: 2026-06-10 01:52:10 UTC
