Page 2 of 3 1 2 3
Re: never thought to ask [Re: Honger] #872335 03/01/08 12:40 AM
Creeper Offline
Four-Wheel Camper.
If we are lucky, KC will post some pictures! =)
Aw shucks Joel.... You know I'm not one to swerve a thread just to promote my own ride..... Yeah right!
Yup, FWC = Four Wheel Camper, a lightweight, pop-up, slide in camper. My FWC has a queen sized bed, 14 gallon water tank and a sink, a 2 burner stove, 16K BTU heater and fridge.
I take it all around the western US. It's a great outfit for getting away from it all - <img src="/forums/images/graemlins/cheers.gif" alt="" />
Montana -
Idaho -
Colorado -
Wyoming -
Utah -
'97 T100 SR5 XCab 4WD
TRD SC ~ ARB ~ FWC
'85 FJ60 Landcruiser
4E9 ~ locked ~ 33's
Re: never thought to ask [Re: Creeper] #872336 03/01/08 05:38 AM
CJMT100 Offline
Last I recall I am getting about 15mpg. But I need a tuneup and new tires since my tires have flat spots. I also need to replace the carrier bearing..
FWIW After I did the snorkel I avg 1mpg or so better, hehe.. 16mpg isnt unusual but I drive the truck so little I cant know for sure.
Re: never thought to ask [Re: CJMT100] #872337 03/01/08 04:32 PM
Jake97T Offline
I got 18 once with 33s at sea level, im thinking i might get 33s again when my 35s are done, take off the body lift and do a spring under in the rear.
Re: never thought to ask [Re: Creeper] #872338 03/01/08 11:38 PM
bkg Offline
Utah -
SEXY!!!
Brian K. Gallus
Re: never thought to ask [Re: toyT100] #872339 03/02/08 01:38 AM
dogslovetrucks Offline
I have driven with the light on for about 15 miles and still never taken more than 19 gallons at the pump... wow... as far as mileage, it is all about how fast I am driving... if I keep it under 75 I get 17+ with a cap, downey brush bar and my groovy new bash plate... I got a little carried away with the plate... went with 1/4 inch al plate and it is super strong... nothing is going through it... well... maybe something... but it is going to be big... and fast... I get killed local driving though... low 14s... I am running BFG all terrain TA k/o
Accidentally did a huge lawn job on my buddies yard today... tried to park, backing it in and noticed the truck seemed to be drifting.. hit the gas and noticed a fine spray of mud shoot past both sides of the truck... oops... he does have a nice pair of parallel trenches to plant something in now... he thought it was hysterical... phew...
Re: never thought to ask [Re: dogslovetrucks] #872340 03/02/08 04:01 AM
CJMT100 Offline
FWIW, I drove about 50 or so miles with the light on and was really crossing my fingers I wouldnt run out of gas. I get to the pump and take in 22 gallons, that means I had 2 more gallons!
Re: never thought to ask [Re: CJMT100] #872341 03/02/08 07:39 PM
L
lawnmowerman Offline
KC,you forgot the best part.Your camper weighs less than 700 Lbs dry!
Re: never thought to ask [Re: Creeper] #872342 03/04/08 11:04 PM
ErikB Offline
Toyota Moderator
Without fail, my light comes on with 5 gallons still in the 24 gallon tank. Figuring a minimum of 15 mpg, I still have a range of about 75 miles when the light comes on.
Don't count on that! Your pump will suck air before the tank is truly empty.
I've run out of gas once and ended up putting in about 22.5 gallons. Generally I figure I've safely got about 40 miles to go when the light first comes on.
FWIW, I get can usually get about 300 miles to a tank before the light comes on and then I can put about 19-20 gallons in (~15+ mpg). 35" tires, 4.56 gears, 3-4" lift, 5spd. Speedo is spot on according to my GPS.
http://home.4x4wire.com/erik
Re: never thought to ask [Re: ErikB] #872343 03/05/08 10:38 PM
kustomyoung Offline
Keep in mind that our fuel pumps are lubricated/cooled by the fuel surrounding/passing through them. Running them close to empty ultimately takes life out of them.
1995 Toyota SR5 T100 4x4
2003 Toyota SR5 Tundra 4x4 *SOLD*
1968 Ford Bronco
Re: never thought to ask [Re: ErikB] #872344 03/06/08 04:29 PM
Creeper Offline
You bite your tongue! NOTHING on my truck sucks! <img src="/forums/images/graemlins/nana.gif" alt="" />
I've driven over 40 miles in 4wd with the light on. It's certainly nothing I would recommend, just trying to show that you still have a fair amount of miles you can go after the light comes on.
*edit - my non-retracting seatbelts kinda suck.... <img src="/forums/images/graemlins/baby.gif" alt="" />
TRD SC ~ ARB ~ FWC
4E9 ~ locked ~ 33's
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6477 MB (Peak: 0.7707 MB) Data Comp: Off Server Time: 2026-06-07 07:26:01 UTC
