how much oil did your motor burn during break-in? #872417 02/29/08 07:37 PM
trashcanman Offline OP
my 22re has burned a quart and a half so far and its only been 150 miles, its worrying me.
Re: how much oil did your motor burn during break-in? [Re: trashcanman] #872418 03/01/08 12:01 AM
N
netgodsrdn2 Offline
It's been over a year since my rebuild, so I don't remember exactly. But I don't think mine burned that much. Did you take it out right away and try to seat the rings?
Re: how much oil did your motor burn during break-in? [Re: trashcanman] #872419 03/02/08 02:28 AM
missouriman Offline
that is alot..
depends on the break in.
some say take it easy, very the rpm's.
others say rod the hell out of it, burn outs, pressure breaking to get the parts to mesh while the machineing is still fresh.
I am not sure what way I lean, but I kinda took it easy and there was not much change, then I started rodding it and that is when it seemed to (break in).
but that is alot of oil.
good luck, post up what you find, I would do a compression check. wet and dry.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.5902 MB (Peak: 0.6432 MB) Data Comp: Off Server Time: 2026-10-24 12:37:24 UTC
