Cab water leaks 90 Montero #872649 03/01/08 11:36 AM
toyhooter Offline OP
I tried the search engine. No luck. Any hints? When it rains I get some wetness on the front carpet. Both passenger and drvers side. Is it the window, floor plugs, fire wall? Any tips would be appreciated. Thanks.
ToyHooter
90 LWB Montero
Sliders, Dual Bouncies, K&N, Flowmaster, Rancho Stabalizer, KYB Gas Adjusts,
ARB Compressor Under Hood, ARB Locker Waiting Garage Floor, Spare Tire Bike/CB Ant Mount
"I didn't do it, you didn't see me, you can't prove it."
Bart Simpson
Re: Cab water leaks 90 Montero [Re: toyhooter] #872650 03/01/08 11:56 AM
CapnCrunch Offline
Could be any of those things or the door seals. Perhaps you have hole rotted through somewhere.
One thought, though. Are you sure it's water, or could it possibly be coolant? Are you losing coolant? The heater pipes and such are up under your dash and if they're leaking, your floor-boards would be wet. I'm just guessing here, but it's possible, I suppose, that you're only experiencing this during rainy days because you're only turning up the heat during those days.
Just a couple thoughts for you. I hope it's just a firewall seal or something.
?_________
|_|_|\____\___
l-----[O]≡≡≡≡[O]
()_)()_)-----)_)
Stay the Trail!
Re: Cab water leaks 90 Montero [Re: CapnCrunch] #872651 03/01/08 03:08 PM
StockRaider Offline
feel around the heater core and lay on your back and check for rusted/missing floor plugs. mine was the combination of the two. <img src="/forums/images/graemlins/frown.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Cab water leaks 90 Montero [Re: toyhooter] #872652 03/01/08 04:47 PM
ghostraider Offline
mine leaks water like crazy...it seeps in around the windshield seal.....
Re: Cab water leaks 90 Montero [Re: ghostraider] #872653 03/01/08 06:05 PM
G
generation_one Offline
that would be my guess.
the roof gutter empties tight on top of the windshield seal.
might be wet fabric/liner on the A pillar
or down at the bottom corners, and will be visible drops on inside near glass
after cleanin these areas get some black adhesive sealant- not 100% silicone ! - and fill the holes.
remember that just one tiny little hole in the right place can flood the floor board.
for best results, start with the most likely areas and see what happens.
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
Re: Cab water leaks 90 Montero [Re: toyhooter] #872654 03/01/08 07:21 PM
heathdogg Offline
Mine leaked around the door seals. I adjusted the door catch (to one on the body) closer to the inside of the truck and it seems to have fixed it.
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.6125 MB (Peak: 0.6830 MB) Data Comp: Off Server Time: 2026-11-19 05:34:41 UTC
