replaced front driveshaft #872857 03/02/08 03:54 PM
bombardj1 Offline OP
I replaced the front driveshaft/propellershaft on my wifes truck the slip-joint was frozen ( I bought one front Everet) (it was a cold night to be under the truck) I wish I had a sawzall I would have just cut the shaft in half, the trans mount did not make it easy to get the flange to the TC mount bolts off plus cold fingers not easy, as I said the slip was frozen, I tried over and over almost got it a few things but the lips on the flanges would not let it drop down, a lift would have helped laying on a cold garage floor did not help, so I said I will try my dremel and some cut off wheels, I cut the ears off the flanges the u-joints are pressed in. The slip-joint on the new shaft was downed out and buy this time my hands were so cold and tried from working all evening then working on this all night I could not pull them out so I put the shalf up in place and just got the bolts started on each flange and tighted up a little at a time. As all of up know smacking you hands or fingers on metal when working is not fun cold and macking is not fun at all <img src="/forums/images/graemlins/zombie.gif" alt="" />, So let see a lift so I could stand the trans mount not in the was a sawzall and I would have gotten a little more sleep that night <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />, my biggest thing is I have this nerver-tumor stuff I was born with, shooting pains in my hands one thing is the last few years if I am out in the cold both index fingers go numb in the cold. I am going to try and work on fixing up the garage better jack and 4 matching stands, compesser, air tools, maybe a sawzall <img src="/forums/images/graemlins/lol.gif" alt="" />. well I will stop my rammbling for now <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> . John
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: replaced front driveshaft [Re: bombardj1] #872858 03/02/08 07:58 PM
Cen_Tex_KIA Offline
Step away from the BFH.............We all know u want to use it! <img src="/forums/images/graemlins/shiner.gif" alt="" />
Yea, cold, pain and grease seem to go together.......and be rather unpleasant. <img src="/forums/images/graemlins/cheers.gif" alt="" />
2000 KIA Sportage 4x4, Sadly Smushed! Now a 2001 Cheep Jerokee. 3" Rough Country Lift, 255/70/16 General AT2's
http://www.cardomain.com/ride/2292811
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5907 MB (Peak: 0.6407 MB) Data Comp: Off Server Time: 2026-05-29 14:58:45 UTC
