Exhaust manifold/ head removal. #872884 03/02/08 08:43 PM
89montero Offline OP
Is there anyway to remove the heads without removing the manifolds? I easily removed the nuts holding the manifold to the head but all the other nuts/bolts holding the manifolds to the rest of the exhaust are frozen solid. I tried prying the manifold away from the heads but couldn't get it far enough away.
Any ideas?
1989 Montero 4dr V6 3.0l
Re: Exhaust manifold/ head removal. [Re: 89montero] #872885 03/02/08 09:18 PM
87Montero Offline
Any ideas?
Get some PB on those downpipe nuts, they are hard to break free but they will(don't strip them!) I've always had to remove the manifolds with the heads, especially on the 3.5l motor.
Re: Exhaust manifold/ head removal. [Re: 89montero] #872886 03/02/08 09:25 PM
FrankR Offline
If you disassemble the Y pipe connection at the converter and at the transmission pan area clamp, the exhaust manifolds should rotate to the side far enough to clear the head studs.
Frank
Re: Exhaust manifold/ head removal. [Re: FrankR] #872887 03/02/08 11:03 PM
Frank
Those are frozen too.
Re: Exhaust manifold/ head removal. [Re: 89montero] #872888 03/03/08 12:09 AM
FrankR Offline
Well, you're gonna have to spray some oil on the bolts and get them off if you want to remove the heads. If the rust is as bad as you say, you'll have to wring some in order to get the job done. Spray some PB Blaster on them, let it sit overnight and try tightening, then loosening. If you break something, just accept it as necessary to get the job done and fix what you break.
Frank
Re: Exhaust manifold/ head removal. [Re: FrankR] #872889 03/03/08 12:23 AM
HondaGuy Offline
Interestingly I just pulled the heads off my 91 without pulling the manifolds. Once the head bolts are loose, you can lift the heads off of the dowel pins and then just slide them towards the center of the engine right off of the manifolds. If you assemble using same method, take extra care not to damage the head gaskets.
Re: Exhaust manifold/ head removal. [Re: HondaGuy] #872890 03/03/08 01:20 AM
Hope fully that will work for me too.
Also what size sockets are the head bolts? I don't have a hex socket that size and can't really bring the engine with me to the hardware store.
Thanks for the help.
Re: Exhaust manifold/ head removal. [Re: FrankR] #872891 03/03/08 02:25 AM
sparkem Offline
Frank
I did this today. I have done it that way on 2 other trucks too. Southern rust free trucks rock.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.007s) Memory: 0.6249 MB (Peak: 0.7200 MB) Data Comp: Off Server Time: 2026-11-02 12:25:28 UTC
