1991 Montero Engine Swap #872911 03/02/08 10:53 PM
torchman Offline OP
I have a few '91 Monteros with one I need to put an engine into. Question: I need some serious horsepower, Is it possible or practical to put a 3000 GTG-----6G72TT [ twin turbo ] in this?
If not I will get another van engine but how can I get some real power to pull a trailer?
Thank You In Advance
Don.
Re: 1991 Montero Engine Swap [Re: torchman] #872912 03/03/08 01:01 PM
W
whitelespaul Offline
There's no replacement for displacement so I'd swap in the Chevy 4.3 l V6 and tranny from a small Blazer. I have a 4.3 in my full size GMC Pickup; it will tow 5000 pounds no problem.
83 mitsu flat bed 2.6l weber, 88 auto tranny, 2" body lift, 4.625 LSD, 235/85-16E mudders (33 x 9.50).
Re: 1991 Montero Engine Swap [Re: whitelespaul] #872913 03/04/08 06:56 PM
A 6G75 3.8 will bolt up to your bellhousing. You will need all the electronics, too.
Re: 1991 Montero Engine Swap [Re: whitelespaul] #872914 03/04/08 07:02 PM
torchman Offline OP
Thank's whitelespaul, I'll look into that. Do you know of any links for for [done it before]?, to save reinventing the wheel. I've done my share of crazy swaps but now I'm getting long in the tooth and short of spare time.
Just got my 4th '91 Montero, a rust free southern rig with a lunched 3.0. It's a 4x4 auto to be my personal daily driver and trailer puller plus snow blade.
If you have done this or have tips on this swap I would be glad to reimburse you a reasonable amount for your time and
advice.. Thank You. Don
torchman
Re: 1991 Montero Engine Swap [Re: torchman] #872915 03/04/08 08:27 PM
W
LandRaider has a chevy V6 swap. Fast Eddy's suggestion has some merit and may be easier than a full drivetrain swap.
Re: 1991 Montero Engine Swap [Re: torchman] #872916 03/07/08 05:22 PM
torchman Offline OP
Thanks wheeler and traileader for the leads.
Another question or two together.
I'm a new poster and most of the time I cant find the archive I need. I read the rules, any tips?
Main problem is the other, better of 2 drivers won't shift to overdrive/lockup and the local ?generic import ?specialist doesen't have a clue. Works fine otherwise.
I would appreciate a few hot diagnosis tips and also how to find this thread in archives. I'm sure it's there.
Thanks, torchman
torchman
Re: 1991 Montero Engine Swap [Re: torchman] #872917 03/07/08 08:01 PM
Yellowhammer Offline
Too bad an I-6 won't fit. Good torque, naturally balanced and very smooth running, and very durable. Good power can be pulled from an I-6 with a little tuning. Some can still be quite fuel efficient too.
1991 Montero LS 3.0 5-Spd LWB 31" Bridgestone Dueller ATs on stock rims, tan/tan interior/exterior
1986 Isuzu Trooper 2.3 5-spd - partially disassembled, tan interior/dark blue exterior
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6110 MB (Peak: 0.6891 MB) Data Comp: Off Server Time: 2026-07-09 14:54:18 UTC
