Where is PCM or ECM located? #872951 03/03/08 01:59 AM
SLXClone Offline OP
Anyone know where the computer is located, need to pull one from an old "98" to put in another "98". Is, the computer located in the interior or under the hood?
Also, does anyone know why rear window windshield fluid sprayer not working. I checked nozzle and pushed a safety pin through to make sure not clogged. I even unscrewed the thing from the window and f tube connector. Reservoir is full, not even fluid comes out of the hose line. Is there a pump that pushes fluid up?
Re: Where is PCM or ECM located? [Re: SLXClone] #872952 03/03/08 02:00 PM
Van Offline
Not sure about the ECM... but it might be under the passenger or drivers seat IIRC.
Check the bottom of the reservoir tank, pump is located there... could be dirty contacts, fuse or pump itself.
HTH
Van <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
'94 Isuzu Pickup, 4x4
NEVER give up...
Re: Where is PCM or ECM located? [Re: SLXClone] #872953 03/04/08 03:28 AM
JLEMOND Offline
ECM AND THE TRANS CONTROLLER IS UNDER THE HOOD IT IS STANDING VERTICALLY ON IT S EDGE THE BIG ALUMINUM BOX WITH THE THREE LARGE WIRING CONNECTORS ON IT , THE WASHER MOTOR IS ON THE BOTTOM OF THE TANK, YOU WILL HAVE TO REMOVE THE RT FRT FENDER INNER SHEILD TO GET TO IT . JERRY
Re: Where is PCM or ECM located? [Re: JLEMOND] #872954 03/29/08 03:59 AM
SLXClone Offline OP
Thanks for the help on the seats JLEMOND, but on the ECM Location you are incorrect. Sorry, for the long delay to repost new information but have not had a chance to jump on here. I was able to pull some info. for ECM location. The ECM is located inside the vehicle, underneath the front center console were automatic stick and 4x4 shift stick are located. Just disconnect battery first, and unscrew screws holding down console, and unscrew 4x4 shift knob, and place vehicle with parking brake and tire stoppers on. Shift vehicle in neutral. Silver rectangle box right below cd radio. <img src="/forums/images/graemlins/drunk.gif" alt="" />
Re: Where is PCM or ECM located? [Re: SLXClone] #872955 03/30/08 07:08 PM
JLEMOND Offline
SORRY ABOUT THAT YOU ARE CORRECT , IT WAS UNDER THE DASH UNTILL 7 OF 99 AND THEN MOVED UNDER THE HOOD , JERRY
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6053 MB (Peak: 0.6707 MB) Data Comp: Off Server Time: 2026-10-24 23:52:42 UTC
