Page 2 of 3 1 2 3
Re: over heating [Re: BigJim] #872999 03/04/08 07:36 AM
BobRowe Offline
You didn't answer the question.. Does it PUKE or just show hot on the gauge?
You need to clean your glasses, BJ. <img src="/forums/images/graemlins/smile.gif" alt="" /> On his second post in this thread, he said it was puking the coolant.
Re: over heating [Re: BobRowe] #873000 03/04/08 06:28 PM
CAskier Offline
Is the thermostat or water pump installed backwards?
Re: over heating [Re: CAskier] #873001 03/04/08 09:27 PM
bud89 Offline OP
water pump only goes 1 way i pulled the thermostat out and it still over heated takes about 10 min. to start puking
Re: over heating [Re: bud89] #873002 03/06/08 11:31 AM
E
el_d_m Offline
if i am not mistaken you have the closed system. i had the same problems on my 90 . i ended up pulling the thermastat & drilling 2 small holes in it. like 1/4 or smaller holes. that allowed the air to burb out fully. those dang closed systems are next to impossible to get all of the air out & that will give you grief. also, keep an eye on your pressure bottle make sure it doesn't start to look like a banana. they have have a really bad habit of warping & that will cause your system to fail. make sure that when you are burping the air out of the system that you have the heater on the whole time.
93 xj stroked 4.2 w/4.0 head avenger supercharged 6.5" long arm 35" buckshots rubicon 44's front & rear
Re: over heating [Re: el_d_m] #873003 03/06/08 04:30 PM
BigJim Offline
In modern heating systems the coolant flows thru the heater core at all times.. So having the heater "ON" doesn't matter a hoot when filling the coolant system.
Re: over heating [Re: BigJim] #873004 03/08/08 09:45 PM
E
el_d_m Offline
in the 1989 & 1990 xj's they used that closed sytsem & they also have that vacuum valve that controls the water flow to the heater core. i wonder if that valve is bad.
Re: over heating [Re: el_d_m] #873005 03/09/08 05:45 AM
bud89 Offline OP
i tried to bypass the heater core and still puking
Re: over heating [Re: bud89] #873006 03/09/08 06:13 AM
E
el_d_m Offline
i am starting to go with Big Jim here & it sounds like a head gasket. my 90 xj was a total whore about the coolant system when i had to breach it once. but wow man you have replaced alot.
how about the lower radiator hose collapsing?? i remember my old 318 doing that alot. used to have to put in valve springs from 454's or 500's LOL just to keep it open.
maybe you had rust or debris or something in the system & after all of the work it worked into a spot & is stopping or seriously restricting the flow?
do you have a temp guage or dummy light in the jeep? maybe you need to see what your temp is when the puking starts?
Re: over heating [Re: el_d_m] #873007 03/09/08 07:54 AM
bud89 Offline OP
it has a gauge and its puking at about 220. i had the head tested at a shop and they said pressure was good
Re: over heating [Re: bud89] #873008 03/09/08 05:28 PM
BigJim Offline
How many times do I have to type it in here? There is only ONE WAY to find a small leak in a head gasket!! That is to fill up the coolant system and keep it full while watching the top level for bubbles while ideling!! It takes all of five minutes and is 100% correct!
If you are too full of yourself to go out and DO IT you will have this problem for a long time...won't you?
You have already found that simply THROWING PARTS at a problem is NEVER the answer.. One must first analize the problem and find what needs to be done before replacing ANYTHING!!
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6394 MB (Peak: 0.7633 MB) Data Comp: Off Server Time: 2026-07-17 02:15:28 UTC
