Yet another charge problem... #873147 03/03/08 10:54 PM
P
PETE_YK Offline OP
Well here we go again...brake/charge lights come on, lights go dim, blower motor slows down etc. you get the picture. Checked and double checked belt tension, all connections, and bench tested alt. Funny thing is: when i start the truck cold it charges normally until it warms up a bit. Also, the brake/charge lights will go off when shes runnin above 2500-ish rpm, and eventually will charge after extended periods of high rpm. Can anyone shed some light here? Thanks.
88' Xtra cab, 22RE, 5 spd, alumi flat deck, 3" BL, 35" muds...awaiting SAS.
'02 Ram, 4.7, REV 'Shooter' wheels wrapped with M.T. Baja claws.
Re: Yet another charge problem... [Re: PETE_YK] #873148 03/03/08 11:57 PM
Adam F Offline
97 4R, stock, daily driver
Re: Yet another charge problem... [Re: Adam F] #873149 03/04/08 12:49 AM
P
PETE_YK Offline OP
Been there, done that. I actually replaced the original alt with a NAPA because i needed one fast and they had one, and the original alt was trashed anyway. Only thing left to do is take the NAPA back, which i dont wonna do again because pulling that bottom rad hose and then refilling is not fun <img src="/forums/images/graemlins/drunk.gif" alt="" />
Re: Yet another charge problem... [Re: PETE_YK] #873150 03/04/08 03:30 AM
mudtoy1986 Offline
well i have had a simalar problem with my 90 toy p/u look around the driver side of the engine compartment look for a larg plug with 3 or 4 wires make shure they arent burned up if they look ok check the main power cable it should run near the larg plug and have a break in it a small plastic box where the wires lead into it its held together with a bolt see if those are coroded or burnt hope that helps you a lil bit
Re: Yet another charge problem... [Re: PETE_YK] #873151 03/05/08 05:02 AM
Bogo Offline
This makes me think bad diodes. After it gets warm it can't handle the current any more and goes to a higher resistance or quits till it can cool down. At higher RPMs you still get charging due to the other diodes passing enough current.
-- Bryan
Re: Yet another charge problem... [Re: Bogo] #873152 03/08/08 05:33 AM
suba Offline
I dunno if this is related, but when my alternator gave me problems it ended up being one of the screws holding in the brush pack was stripped. It happend to be the one with the ground strap attached too, so it was making intermitent contact. if you've already done the brush pack though that doesn't make much sense. I'd be inclined to agree with Bogo as well, especially since bad diodes seem to have a tendency not to show up in bench tests. Also, you *can* get the alternator out without taking off the radiator hose, but it usually hurts. If you take out the lower radiator bolts you can usually wiggle it free and not mess with coolant.
86 4runner, pro comp AAL, Kayline Soft top, 31's but all stock
Re: Yet another charge problem... [Re: PETE_YK] #873153 03/08/08 08:56 AM
Davepet Offline
My guess is a bad solder joint inside the alternator. Connects when cold & opens when warm. You're probably gonna have to pull that alternator one way or the other...
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6185 MB (Peak: 0.6934 MB) Data Comp: Off Server Time: 2026-07-14 08:17:33 UTC
