89 pioneer transfer case/front axle stuck #873551 03/05/08 10:48 PM
E
ekent4 Offline OP
MY FRONT AXLE WONT DISENGAGE,I HAVE HAD TO REMOVE THE FRONT DRIVE SHAFT TO SAVE SOME WEAR AND TEAR AS IT IS MY DAILY DRIVER.THE VACUME LINES TO THE AXLE FROM THE TRANSFER CASE ARE OK AND TIGHTLY CONNECTED.I HAD A JEEP DEALER TECH SAY THE TRANSFER CASE MUST BE REBUILT @ 1350.00 TO FIX THE PROBLEM.DOES THIS SOUND RIGHT?,WOULD I HAVE ANY OTHER OPTIONS?AS A SIDE NOTE THE 4WD INDICATOR LIGHT STAYS ON WHEN DRIVING BUT DOES GO OFF IF THE ACCELERATOR IS PRESSED DOWN SLIGHTLY AGGRESSIVLY,LIKE GOING ALONG THEN DROP THE PEDAL ANOTHER 3/4",NOT FLOORING IT,COULD THIS BE RELATED?THANKS FOR TAKING THE TIME TO READ ALL THIS,I HOPE SOMEONE CAN HELP.
Re: 89 pioneer transfer case/front axle stuck [Re: ekent4] #873552 03/09/08 01:45 PM
E
ekent4 Offline OP
is there another way to engage/disengage the axle?
Re: 89 pioneer transfer case/front axle stuck [Re: ekent4] #873553 03/09/08 05:32 PM
BigJim Offline
Sounds like a vacuume leak don't it? I betcha finding and repairing the vac leak is all that ride needs.
AND I never heard of the repair your mechanic advised ...stay away from there in the future..
Find the leak and you will be 99% done.
Re: 89 pioneer transfer case/front axle stuck [Re: ekent4] #873554 03/09/08 09:19 PM
jstritec Offline
I would agree with BJ. When you press the pedal you will get a change in vacuum that controls the disconnect.
Posi-lock makes a manual conversion.
FYI, found this guy who made his own:
I think he sells them on e-bay
http://home.earthlink.net/~stevenschreiber/jeep/tech/cabledis.htm
Josh
80 CJ-7.
It runs
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6009 MB (Peak: 0.6565 MB) Data Comp: Off Server Time: 2026-06-20 20:27:08 UTC
