Water on pass. floor & source for window gaskets, source? #873596 03/06/08 03:10 PM
Buffalo86 Offline OP
While I was removing the AC system, I ended up with the Rubber hose that water drains out the cowl vent. It goes through the firewall somewhere, but I can't figure out where. It's a prebent hose about 9" X 3/4".
Also, I need the the two rigid gaskets that go inside and outside the window glass. Can you recomend a good source for that kind of stuff? I'm getting new doors for it this spring and mine are not worth re-using.
Re: Water on pass. floor & source for window gaskets, source? [Re: Buffalo86] #873597 03/07/08 07:37 AM
OOP'S Offline
That is a drain for the AC condensing unit. Has nothing to do with the cowl drain. The cowl drains out of the sides by the fenders.
Any good auto glass shop should be able to get you the gaskets.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5868 MB (Peak: 0.6348 MB) Data Comp: Off Server Time: 2026-06-07 09:10:08 UTC
