Stripped PS mount hole #874101 03/09/08 06:17 AM
slappy Offline OP
While doing some 200K maintenance, I was trying to put my PS pump back in after changing the timing belt. The big 14mm bolt would screw right in and tighten, but I think both of the smaller 12mm bolts stripped out the hole in the bracket where they go. (I may have tightened them a wee much last time). They would bite at first, but never tightened.
Short of a new PS pump, are there any ideas on how to repair these stripped holes on the pump? I was thinking of some JB weld and then re-tapping, but I'm not sure how well that would work on an aluminum housing.
-john
99 Rodeo 3.2L 4WD
Re: Stripped PS mount hole [Re: slappy] #874102 03/09/08 02:14 PM
litnin Offline
Either take the bracket off, ground the welded nut off them
and re-weld a new nut on or get drill them out, get a slightly
longer bolt, and put a good nut on the backside.
I'd ground off the stripped nut and weld a new one on in its place.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: Stripped PS mount hole [Re: litnin] #874103 03/09/08 05:15 PM
Van Offline
You could drill and tap it to a 14mm size bolt or try a SAE size bolt 7/16 - 9/16 (not sure on the size).
HTH
Van <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
'94 Isuzu Pickup, 4x4
NEVER give up...
Re: Stripped PS mount hole [Re: Van] #874104 03/09/08 06:19 PM
slappy Offline OP
Problem is, there's no nut on the backside. The bolt goes through the bracket into the pump and stops. It's only a small M8x25 (12mm) bolt that's supposed to go in there.
The main 14mm bolt does the same thing, but it's longer and actually threads into the block to secure it. I figure that is the main support bolt, while the other two just keep the pump from rattling around.
-john
99 Rodeo 3.2L 4WD
Re: Stripped PS mount hole [Re: slappy] #874105 03/09/08 10:18 PM
Van Offline
"while the other two just keep the pump from rattling around"..... if that's the case, then wrap some plumbers Teflon tape around the bolts and put some Locktite on 'em.
WARNING: Temporary <img src="/forums/images/graemlins/notooth.gif" alt="" /> fix.
HTH
NEVER give up...
Re: Stripped PS mount hole [Re: Van] #874106 03/10/08 12:31 AM
slappy Offline OP
I think I'm going to try that "form a thread" stuff. I don't have a tap and die at my disposal. If that's no bueno, then we'll do it the hard way.
Temporary is my middle name.
Thanks, guys...
-john
99 Rodeo 3.2L 4WD
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6120 MB (Peak: 0.6824 MB) Data Comp: Off Server Time: 2026-10-24 08:16:11 UTC
