fuel smell? #874116 03/09/08 06:35 AM
L
Landon Offline OP
im new to this forum. but i have a really bad fuel leak on my 95 cherokee. Cant find any leak anywhere. Been told its the charcol canister. somebody help
Re: fuel smell? [Re: Landon] #874117 03/09/08 10:59 AM
the_other_guy Offline
where is the leak coming from? on mine it was just a dirty rubber gasket on the buel filter on top of the tank. I took it off, cleaned it and put it back on with a spacer in the spring clip, so it would stay on tighter. that fixed it up perfect. (im not sure if the pre 97 cherokees have a different tank set up tho.)
Your road to glory will be rocky, but fulfilling.
- Panda Express fortune cookie
94 YJ. no lift...YET
Re: fuel smell? [Re: the_other_guy] #874118 03/09/08 05:53 PM
BigJim Offline
In my experiences most gasoline smells that don't have an obvious wet place or drip have been from the TANK AREA.
Re: fuel smell? [Re: BigJim] #874119 03/09/08 11:18 PM
52degrees Offline
I've looked at Landon's Cherokee several times for this, and I have yet to find any clear signs of leakage.
He's getting a very strong fuel odor when driving. It's choking him out inside the cab even at freeway speeds.
Personally, I think it's got something to do with the exhaust pipe ending underneath the truck in front of the rear axle, but having never actually smelled what he's complaining of, I couldn't tell for sure. It's fairly plausible though, as he has a small pile of aftermarket engine performance goodies all over under the hood.
I think what Landon is hoping for with his post (incidentally, his first on 4x4Wire), is for someone to chime in who has had a similar problem and fixed it. This is his first time ever on a web forum, so please go easy on him.
<img src="/forums/images/graemlins/patriot.gif" alt="" />
KG6VNX
Re: fuel smell? [Re: 52degrees] #874120 03/09/08 11:30 PM
BigJim Offline
If it is an exhaust smell... wouldn't that be a smellable difference from a gasoline smell? Is the vehicle CLOSED when the smell happens or are there windows open?
Re: fuel smell? [Re: 52degrees] #874121 03/09/08 11:32 PM
playinmud Offline
my buddy has an 88 cherokee with an exhaust that exits under the middle of the jeep, after about 15 minutes of driving you get the smell of exhaust fumes inside the jeep
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
Re: fuel smell? [Re: playinmud] #874122 03/10/08 06:41 PM
Seattlegti Offline
Not a problem to ignore.
My buddys 88 Cherokee caught fire last week due a leaking injector and burned up the entire engine compartment before they could get it put out.(Hard to open a hood when there fire under it!)
The vehicle is a total loss. We'll pull the ARB locked axles, winch bumper and lift out but pretty much eveything electrical and plastic is shot.
He noted a slight gas smell in the cab the day before it caught fire.
Re: fuel smell? [Re: Landon] #874123 03/12/08 11:00 AM
E
el_d_m Offline
the injectors like to leak on the xj's the seals go out on them. the vent lines on top of the gas tank will come loose sometimes & give you that smell. check all of the hoses & fuel filter follow them down the frame & under the hood. fix it quick though fires suck.
93 xj stroked 4.2 w/4.0 head avenger supercharged 6.5" long arm 35" buckshots rubicon 44's front & rear
Re: fuel smell? [Re: Landon] #874124 03/19/08 10:09 AM
drifter Offline
Take it to a different mechanic,what you have is a gas leak maybe a damage or broken line and they will change some auto parts of the car, be carefull any spark near the leak will make the car get on fire, don't take it to the same guy anymore take it to a real mechanic shop might cost you little more but will save you from problems and even your life.
Re: fuel smell? [Re: drifter] #874125 03/20/08 06:11 AM
52degrees Offline
KG6VNX
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6336 MB (Peak: 0.7417 MB) Data Comp: Off Server Time: 2026-06-07 09:08:43 UTC
