Bad Spark Plug #874515 03/10/08 10:57 PM
toddstidham1 Offline OP
Just thought I'd post up a little FYI. My Monty has been running great these past months and two weeks ago I finally put new rear shocks on. WOW what a difference in ride. Anyway, as luck would have it, the day after I go to start her up and she's mis-firing really bad. <img src="/forums/images/graemlins/barf.gif" alt="" /> As I rev it up it smooths out but at anything below 1500 rpm it's a three cylinder. It was way too cold to look into it so I let her sit until today. Long story short, I pull plug wires while it's idling and find #2 ain't firing. I pull the plug and check it and it looks fine (they were new 2 months ago) so I spray some brake cleaner (it was all I had) on it to clean it up some and that's when I see the crack in the electrode ceramic (as the cleaner evaporated the crack showed up clear as day). Popped a new plug in and she's running great again. <img src="/forums/images/graemlins/kewl.gif" alt="" /> It must have been arcing inside the plug and not lighting the fuel off at low speed and at higher RPM I guess there was enough swirl or something to ignite.
So if you need to check your plugs, spray some brake clean on the ceramic and watch as it evaporates.
-Todd
1987 Montero 2.6l 5-speed (Sold...but I still miss her)
2008 Jeep Patriot Sport 4x4
Re: Bad Spark Plug [Re: toddstidham1] #874516 03/10/08 11:04 PM
redbull Offline
Spark plugs? What are those?
<img src="/forums/images/graemlins/wink.gif" alt="" /> J/K, stupid diesel driver's joke. Glad you solved it.
Re: Bad Spark Plug [Re: toddstidham1] #874517 03/10/08 11:25 PM
P
pcc Offline
Here's another spark plug story.
My chain saw had trouble starting and running. I did everything I thought to fix it. I had pulled the plug and inspection showed it to be ok. Well I had the plug out again and almost accidently turned it so the tip was facing down. As I did that I noticed the ceramic below the center electrode slipped down the electrode and closed the plug gap. When I turned the plug tip end up the ceramic slid back to the proper position. Replaced the plug, worked fine.
Re: Bad Spark Plug [Re: redbull] #874518 03/11/08 01:32 AM
Oh how I wish I could afford to switch this to a diesel. There's a 2.8L TD on ebay right now but the price is too steep for my pockets (for a used motor anyway). Plus I figure I could probably get one imported myself for cheaper if I felt like going through all the paperwork. But if I ever did, I would be home brewing some bio-diesel and tell the middle east to stick it.
Wow, that chain saw plug...that is bizarre!
-Todd
Re: Bad Spark Plug [Re: toddstidham1] #874519 03/11/08 02:36 AM
2.6 turbo motor. Plugs gapped to .39. Brand new NGK's. Every time I'd wind it up past 4500, it would misfire like crazy and kill the power and boost. Finally found a post somewhere that said that wide stock gaps have the spark blown out by the turbulence in a forced induction motor. Closed the gap to .32, and the misfire went away, and never came back.
better one. Had a good running 2.6T motor with about 6000 on the plugs, so I pulled them for a new set. Motor had the smoothest idle I ever had on a 2.6, and pulled like a bandit at wot, and cruised like silk. The #1 plug had no center electrode or ceramic at all showing, broken off almost half an inch down inside the threads. Nothing in the cylinder (and no scars) showing with a borescope. No dings on the turbo exhaust wheel. No spark plug guts lying in the cat. inlet. And I have no idea how it was firing the cylinder. I could get no visible sparks from it out of the motor with wire attached and shell grounded. 'splain that one...
Re: Bad Spark Plug [Re: fasteddy] #874520 03/11/08 02:03 PM
hazy_daze Offline
Spark jumped to the top of the piston or head itself?
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.012s) Memory: 0.6135 MB (Peak: 0.6853 MB) Data Comp: Off Server Time: 2026-11-18 03:28:10 UTC
