Electrical Question #874721 03/11/08 07:22 PM
RockRidge Offline OP
I have only had my YJ for about 4 weeks now and this is my first Jeep. I have been reading with much interest the threads about guage problems. So far I've replaced the Battery, starter and partially rebuilt the carb. At least now it runs. I'm in the process of replacing the ignition key switch, since the PO broke the key off inside.
Here's my problem. the Jeep runs ok (even though the idle is REAL HIGH), but the only guages that work are the clock and the speedometer, I assume because they're mechanical. I haven't yet checked the fuse (#9, 15 amp) for the guages to see if it's blown. I checked all the fuses a few weeks ago (before I got it running) and they were all good, but not since then. If it's not the fuse, what else should I be looking at?
Thanks again for all your assistance!
1990 YJ 4.2L Carb, 31x10.5.15, AX-15, Mostly Stock (The Red Sled)
2008 F-350 Superduty 4x4 350 HP/650 TQ (The Tow Beast)
Re: Electrical Question [Re: RockRidge] #874722 03/11/08 08:22 PM
BigJim Offline
Them yj's have a lot of grounding problems.. Make sure the cluster is properly grounded.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.5842 MB (Peak: 0.6324 MB) Data Comp: Off Server Time: 2026-07-17 04:36:24 UTC
