would this be a faulty water pump issue #874897 03/12/08 09:44 PM
Thor Offline OP
I changed my spark plugs and they porcelain in them was burn away, they weren't even that old either, I took them out and they were like just gone! would this be a issue as to not enough water pumping through (as a water pump was installed by a mechanic) and what would have happened to those Porcelain pieces...(yes i know they are in there, but would they do really bad damage?
89 Montero, 2.6L 4cylinder. G54B
Re: would this be a faulty water pump issue [Re: Thor] #874898 03/12/08 10:22 PM
93montero_sr Offline
When was the last time you changed your plug wires? The water pump dosent pump water into the combustion chamber. The porcelin sits in side the plug wire. Did it happen to all of them or just one? Maybe you broke one installing the spark plug.
93 montero sr 3 inch body lift 31x11.50 super swamper ltb, 2 8inch 130 watt pro comp off road lights, 2 55w lights on the rear bumper, rear air locker, magnaflow exhaust muffler,superwinch manual hubs,15x8 black rock crawlers (steel)
Re: would this be a faulty water pump issue [Re: Thor] #874899 03/13/08 01:33 PM
toddstidham1 Offline
Might be running lean and have detonation problem (pinging). Excessive carbon buildup in the combustion chamber can also cause this. One way you can "clean" the combustion chambers some is to spray some water into the carb while running it at like 3k rpm using an old windex bottle. The water turns to steam inside the engine (much like what happens when you blow a head gasket). Obviously too much water and you risk hydro locking and blowing the motor, too little and nothing is happening. GM used to sell this stuff called top cylinder clean that you would pour into the carburetor of the older V8's while running, but then those were non-catalyst cars and sometimes you could actually see chunks of carbon flying out the exhaust pipes. More then likely the porcelain chunks are sitting down in your cat converter now.
-Todd
1987 Montero 2.6l 5-speed (Sold...but I still miss her)
2008 Jeep Patriot Sport 4x4
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.5945 MB (Peak: 0.6478 MB) Data Comp: Off Server Time: 2026-11-03 12:26:45 UTC
