91 trooper LSD
#875013
03/13/08 07:00 AM
I searched and couldn't find this, I found everything else about LSD's though. So here is my question. I have 91 trooper without the LSD and I want to find one for it. What models and years of Isuzu's SUV's can I get one from. and do I need to change the whole rear end or just everything in the Diff. My local salvage yard has a 2000 with a G80 but they say it won't fit. I thought I saw somewhere on here that all troopers after 88 had the 12 bolt rear end. Any feedback you guys can give would be greatly appreciated. Thanks
Re: 91 trooper LSD
[Re: BillW]
#875014
03/13/08 02:41 PM
98 and newer will NOT fit. That is the "modified" 12-bolt...pretty much everything is different except the housing, including the gear ratio. Everything 97 and older should fit and have the same 4.56 gears...some might have an ABS sensor ring (for rear ABS) but I don't think that is a problem for you.
And yes, you can swap out the "third member" (don't ask me where the name came from) without removing the axle. You do have to pull the axle shafts out a few inches to disengage them from the diff, then it is a matter of unbolting the driveshaft and the third member housing and pull 'er out.
It is not too difficult, I have done it a couple of times now. The hardest part was re-assembling the emergency brakes the first time...but your e-brake might be different than mine. I'm a little hazy on first gen details.
Steve Carlson - 95 Trooper LS expo rig Serenity now!
Re: 91 trooper LSD
[Re: BillW]
#875015
03/18/08 03:25 AM
Powerbrute LSD I bought the front one.
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5911 MB (Peak: 0.6451 MB) Data Comp: Off Server Time: 2026-06-09 23:06:48 UTCValid HTML 5 and Valid CSS
