ford 400 highboy
#875230
03/15/08 03:36 AM
My wifes kid brother just bought what he says is an f-250 high boy with a 400. I know next to nothing about this kind of stuff so here goes. The truck will not idle. He has checked the vacuum lines and all are ok. There is a missing line with suction coming out of the back of the intake manifold near the firewall. Cannot find what it may go to. Blocked it off and it seemed to at least try to idle. Distributer has no moisture in it and looks pretty good. The spark plug bases are rusted so I told him he probably needs to yank em and look at em. Made sure he did not mix up firing sequence. Quite a bit of oil blowing out of vacuum barb on back of manifold. Carb is a 2 barrel motorcraft. Any help would be appreciated. Thanks.
Re: ford 400 highboy
[Re: chicomilo]
#875231
03/19/08 12:40 AM
Oil shouldn't be blowing from the intake manifold. The engine EGR system may be plugged or there could be significant blowby. Have you checked for a vacuum leak in the carb base or throttle shaft? Does the 400 have the intake manifold the mounts under the valve cover, like the 360/390/460-series engines? Could be some leaks along the intake manifold to head also. Try uncapping the oil fill cap and run the engine, feel for the blowby there. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: chicomilo]
#875232
03/23/08 04:34 PM
need a little info. is the truck stick or auto trans? trying to answer question about vacume line. otherwise I agree with rxinhead. Let us know what you find. BTW where in Illinois?
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5929 MB (Peak: 0.6465 MB) Data Comp: Off Server Time: 2026-06-13 10:46:10 UTCValid HTML 5 and Valid CSS
