Jeep Cherokee #875407 03/16/08 02:23 AM
E
ElmerFudd360 Offline OP
I have a jeep cherokee and i'm having a problem with it missing when you get it moving it idles fine. I have changed the fuel filter, throttle position sensor, o-rings on the injectors, cap/rotor, plugs does anyone know what i should do next?
Re: Jeep Cherokee [Re: ElmerFudd360] #875408 03/16/08 03:57 AM
BigJim Offline
Give a bit more information please.. Does it miss at 1000 rpm? Will it get to hiway speed?
How does it miss? Does it pop and crackle?
Re: Jeep Cherokee [Re: BigJim] #875409 03/16/08 04:02 AM
Brown81CJ5 Offline
What kinda voltage is your coil reading? Maybe you have a dying battery, a bad plug wire, or a bad coil.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: Jeep Cherokee [Re: BigJim] #875410 03/16/08 04:32 AM
E
at idle it runs great but as soon as your get going it pops sputters dies and it really feels like it's not getting gas. then i put it neutral rev up the motor and get some kind of responce but not much. a friend said it was clogged injectors and one said it was the o-rings so we changed them but nothing has helped
Re: Jeep Cherokee [Re: BigJim] #875411 03/16/08 04:35 AM
E
oh no it does not get to highway speed.
Re: Jeep Cherokee [Re: ElmerFudd360] #875412 03/16/08 04:47 AM
the_other_guy Offline
could it be a bad fuel pump?
Your road to glory will be rocky, but fulfilling.
- Panda Express fortune cookie
94 YJ. no lift...YET
Re: Jeep Cherokee [Re: the_other_guy] #875413 03/16/08 05:21 AM
BigJim Offline
Put a new coil on it before changing anything else..
Re: Jeep Cherokee [Re: BigJim] #875414 03/16/08 05:34 AM
BigJim Offline
Popping occurs when there is fuel and the spark gets cut on and off.. I'd betcha money it ain't a fuel problem.. Most likely a coil or in extreme cases a simple lectric tune would do the trick.
Re: Jeep Cherokee [Re: BigJim] #875415 03/17/08 01:41 AM
E
Coil is good. do you think it could be the catalytic convertor? when i push on the break and give it gas the jeep sputters and almost dies one of the guys at the part store thought it might be the convertor, what do you think.
Re: Jeep Cherokee [Re: ElmerFudd360] #875416 03/17/08 02:00 AM
BigJim Offline
Stopped up exhaust will cause an extreme slowdown...I've never heard of one causing sputtering.
COILS cause sputtering.. They should be replaces with every new set of spark plugs.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6366 MB (Peak: 0.7433 MB) Data Comp: Off Server Time: 2026-06-07 03:13:45 UTC
