86 toyota 4x4 wheels/ mags #875876 03/17/08 07:58 PM
moto629 Offline OP
i've got an 86 toyota 4x4 15" wheels, does anyone know if 79 chevy 4x4 15" aluminum wheels will bolt on to the 86 toyota, I believe the bolt pattern is the same, but i'm not sure about the offset? thanks in advance for any info.
Re: 86 toyota 4x4 wheels/ mags [Re: moto629] #875877 03/17/08 08:18 PM
toyomorph Offline
If I remember right, the chevy wheels may be a little tight going over a toyota hub. If they go on they'll bolt up.
I don't think there's a problem with the offset. Someone else may know for 100% sure.
Re: 86 toyota 4x4 wheels/ mags [Re: toyomorph] #875878 03/17/08 08:56 PM
4Crawler Offline
You can measure the offset or backspacing and compare that to your wheels (yours should be 4-3/4"):
Likewise check the ID of the center hub hole to make sure it is big enough to clear your front hubs, usually around 4-1/8" or so.
Re: 86 toyota 4x4 wheels/ mags [Re: 4Crawler] #875879 03/18/08 03:17 AM
L
Locked_Solid_Toy Offline
yeah if it fits over the hub, should fit, the six lug patterns are the same. should clear everything else as well, b/c the some of the stock rims of an IfS yota won't clear the tie rods on the solid axle yotas, i.e you have a better chance of fitting them on an IFS than SAS.
1985 yota 22RJasper motor w/ cam,webber carb.Marlin histeer & 4"springs, AllPro jonny jointshackles. Bds yj springs upfront. Bilstein 5150's all around. 4.88 yukon gears,detroit locker and truetrac. Fj80 Master cylinder, 33" MTR's
Re: 86 toyota 4x4 wheels/ mags [Re: Locked_Solid_Toy] #875880 03/18/08 09:57 PM
dcg9381 Offline
Agree.. my understanding is the bolt pattern is close enough - BS may cause problems.
I'm running 16' wheels from an 07 Tacoma. They barely clear the IFS due to BS issues - in fact, inner mounted wheel weights had to be pulled.
22REturbo.net
1988 4Runner
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.012s) Memory: 0.6093 MB (Peak: 0.6737 MB) Data Comp: Off Server Time: 2026-11-16 08:48:25 UTC
