Code 12 mass airflow sensor problem #876104 03/19/08 01:04 AM
Bertdog Offline OP
In the last week my check engine light comes on and goes off. It seems that it comes on if I let up on the gas pedal. It seems to come on more regular now. I try to self ûdiagnosis by using a voltmeter but couldnÆt figure it out. So I took it to my local mechanic and he came up with code
#12 Mass air flow sensor problem and code
# 21 coolant temp signal out of range
He said that #21 was not a problem but #12 could be a big cost.
Has anyone gone thru this?
Any advice to what I should do?
1989 raider 3.0 liters
Eng 6G72
5 speed
72,300 miles
Everything is still kept stock and it seem original
Thanks ahead of time last time you were very helpful
Re: Code 12 mass airflow sensor problem [Re: Bertdog] #876105 03/19/08 01:33 PM
toddstidham1 Offline
Easiest and cheapest is gonna be the #21 code. The computer relies on accurate engine temperature to regulate how much fuel goes in. I'd fix that one first. I know the Mass air sensors on the v6's aren't cheap so maybe a junk yard unit would be best to try to fix that one. You'll probably see a pretty big fuel mileage jump just fixing the temp sensor problem though.
-Todd
1987 Montero 2.6l 5-speed (Sold...but I still miss her)
2008 Jeep Patriot Sport 4x4
Re: Code 12 mass airflow sensor problem [Re: toddstidham1] #876106 03/22/08 01:44 AM
Bertdog Offline OP
Thanks for the info. It seems that I got lucky this time. The breather hose that connects to bottom of the air intake hose. Had come off, which caused it run a bit out of idle and may have affected the mass air flow sensor. But anyway I took your advice and replace the heat sensor , and my mechanic happen to have had a used sensor laying around so I bought it from him got home to do the work and thatÆs when I discovered the loose connection . Spare parts are a good thing for the raider and y wallet.
Thanks again
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5936 MB (Peak: 0.6473 MB) Data Comp: Off Server Time: 2026-06-20 18:02:11 UTC
