Some kind of hesitation during acceleration #876112 03/19/08 02:04 AM
mama Offline OP
Do the NGK plugs for a 22re have to be gapped? I gapped a set and made the problems I was having seem a little worse.
I pulled them and put a set in ungapped I still have the same issue. The plugs had dark Carbon around the ring and thin white soot on the prong.
I replaced the 02 Sensor and used the same gasket it didn't seem like that big of a deal looke to be in good condition.
I saw an article on checking the MAF sensor. My wrenching level does not really include electronics past basics.
Is there a simple test to see if the sensor works? The search using Mass airflow resulted in one article similar to the topic.
The problem I really notice in first and second is hesitation then all of the sudden power. I assumed it needed a tune up so plugs, Removed the D cap cleaned contacts(it was under a year old) same with the rotor, pcv valve, O2 sensor. I will continue searching the forum. Could it also be the EGR? I know these are the most annoying posts but I can't start the bumper build without this being out of the way.
90 toy
dx
Acura seats and almost perfect matched paint.
Re: Some kind of hesitation during acceleration [Re: mama] #876113 03/19/08 02:47 AM
4Crawler Offline
You likely have an Air Flow Meter (AFM) instead of a Mass Air Flow sensor (MAF). It can be tested as follows:
- http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
Re: Some kind of hesitation during acceleration [Re: 4Crawler] #876114 03/19/08 02:54 AM
mama Offline OP
Thanks 4crawler, I actually just found a post with similar complaint. It ended up being the guys 02 sensor. I got the bosch with the clip already on it noticed from the old sensor that their was a great deal of difference between the nub on the 02 one was half an inch or so longer than the bosch and had a different set up. Then in your response post you suggested a denso sensor. You have been most helpful and I thank you for your time. will check it out.
Also I just got the approval hopefully for the headlight mod for my birthday. Girlfriend rolled her eyes at me. <img src="/forums/images/graemlins/notooth.gif" alt="" />
90 toy
dx
Re: Some kind of hesitation during acceleration [Re: mama] #876115 03/19/08 08:08 AM
mama Offline OP
I ran the test as per 4crawler instructions,
Mid sixties (local temp) These are the results.
1.E2,Vs=92
2.E2,Vc=180
3.E2,Vb=296
4.E2,THA=589
5.E1,Fc= no response
Test at running temp(approx)15 mins driving.
1.E1,Fc= no response
2.E2,Vs=189 (closed)/683 (open)
I believe it is safe to assume that these readings mean the AFM is not the culprit? This was a cheap multimeter from Harbor Freight so the numbers bounced around 15 plus or minus on some of the readings.
90 toy
dx
Re: Some kind of hesitation during acceleration [Re: mama] #876116 03/21/08 03:38 AM
94svt50 Offline
I would lean toward the 02 sensor as well. Thats what caused me all kinds of grief untill I switched back to OEM brand.
-1989 4x4 22re(pretty good in the mud)
- custom steel flat bed-oneside of exhaust system, and air box intake off cobra.(doesnt quite have the v8 rumble)AFM off '82 Supra.
-Destination M/T 31"-KYB monomax shocks-"add a leaf"
Re: Some kind of hesitation during acceleration [Re: 94svt50] #876117 03/21/08 05:39 AM
mama Offline OP
Yeah I have the Bosch, I just ordered the denso online and it should be in some time next week. Then I am gonna try and get store credit on the bosch becuase it has a 90 day warranty.
90 toy
dx
Re: Some kind of hesitation during acceleration [Re: mama] #876118 03/27/08 04:44 AM
mama Offline OP
I am up one denso O2 sensor and 93 bucks for the bosch. The guys at autozone looked at me like I was dumb and it took 20 minutes but I got my money back.
The problem also seemed to clear up. We will see after a tank or two of gas. Thanks for all input and assistance. <img src="/forums/images/graemlins/kewl.gif" alt="" />
90 toy
dx
Re: Hesitation and O2 sensor question [Re: mama] #876119 03/27/08 05:09 PM
P
Pyroboy Offline
I have a similar problem but didn't consider the O2 sensor. It was replaced twice, a long time ago, but only after the "engine" light came on. Could an O2 sensor be bad without causing the light to come on?
Thanks.
1989 4Runner Special Edition
22RE, 5-spd.
TG 3" SAS, MC DuaLs, 4.56s, Air Locker
Hi-Clearance panels by
www.toyotafiberglass.com
Re: Hesitation and O2 sensor question [Re: Pyroboy] #876120 03/27/08 06:30 PM
G
Greg_Canada Offline
Thanks.
is it a bosch or denso/ngk o2 sensor?
89 4Runner
Re: Hesitation and O2 sensor question [Re: Greg_Canada] #876121 03/28/08 02:54 AM
P
Pyroboy Offline
Not sure. I bought it from a dealer so I assume it's a Denso. Is there an easy way to tell them apart?
22RE, 5-spd.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6400 MB (Peak: 0.7652 MB) Data Comp: Off Server Time: 2026-06-07 08:37:21 UTC
