Replace the O2 sensor? #876165 03/19/08 02:19 PM
MuddRunner Offline OP
My truck had been running very rich due to an air flow meter problem I have since corrected. It's running fine now, and after the test run I pulled the plugs to clean and they actually looked very good. I have some concern that my O2 sensor may have gotten coated or dirty.
1. Do you think this could be a problem?
2. Can it be cleaned if it is actually dirty?
3. Or should I just plan on replacing it? I believe it's the original, truck has 200+K miles...
'92 Pickup x-cab, 22re, auto.
'50 Ford Tudor Sedan, my new "Hot Rod"
Too much to do, too little time/$$$
Heb. 12.3
Re: Replace the O2 sensor? [Re: MuddRunner] #876166 03/19/08 03:32 PM
G
Greg_Canada Offline
If it's running fine it should be fine.
But it's not too expensive to replace.
Make sure you get a denso or NGK.
for best prices and good service, go to www.sparkplugs.com... my bud got one last week from them and said the customer service was fantastic.
89 4Runner
Re: Replace the O2 sensor? [Re: Greg_Canada] #876167 03/19/08 03:42 PM
Do you know if there is a difference between the universal and the oem style besides the $40.00?
Heb. 12.3
Re: Replace the O2 sensor? [Re: MuddRunner] #876168 03/19/08 03:56 PM
G
Greg_Canada Offline
OEM will plug right in and universal just has some wires on it.
Personally i would just get the plug and play.
But if you feel like busting out the truck's wiring diagram and cut+solder the new connections, it's up to you.
I'd just pay $40 for the *right* one, cause you know it's going to be perfect.
89 4Runner
Re: Replace the O2 sensor? [Re: Greg_Canada] #876169 03/19/08 04:29 PM
thanks...
Heb. 12.3
Re: Replace the O2 sensor? [Re: MuddRunner] #876170 03/19/08 05:07 PM
O
OutlawMike Offline
I've always wondered about the affect that the extra wire connections my have on the signal from the O2 sensor for the cut and splice versions. I've seen some people use crimp connectors, rather than soldering the wires. Not knowing how sensitive the sensors are, I have always gone with the OEM style plug in versions.
Re: Replace the O2 sensor? [Re: OutlawMike] #876171 03/19/08 10:24 PM
G
Greg_Canada Offline
I would never crimp outside connections because there is a bigger opportunity to get grime/debris/mud/etc in there.
Always solder and heat shrink.... stronger connection and weather tight... its also much cleaner/nice looking...
89 4Runner
Re: Replace the O2 sensor? [Re: OutlawMike] #876172 03/20/08 05:13 AM
dcg9381 Offline
There shouldn't be "extra" connections. There may or may not be a shared ground wire.. The signal and ground wires are critical. Solder. Don't crimp. For $40 I'm doing it myself..
22REturbo.net
1988 4Runner
Re: Replace the O2 sensor? [Re: Greg_Canada] #876173 03/20/08 01:45 PM
Always solder and heat shrink.... stronger connection and weather tight... [color:"blue"]its also much cleaner/nice looking...[/color]
Which is always important [color:"blue"]under [/color]my trucks... <img src="/forums/images/graemlins/lol.gif" alt="" />
Heb. 12.3
Re: Replace the O2 sensor? [Re: MuddRunner] #876174 03/20/08 07:12 PM
RatLabGuy Offline
The Bosch universal one comes with this cool little kit whereby you "make" a connector, screw these little threaded pieces onto the end of the wires, the thread and crimp on as they go down, then teh two halves connect together. I did this on mine a few years ago... when I replaced my exhaust, some !@#$ PO has welded the o2 sensor into place.
Now... I have never felt like the a/f ratio was good after that, always been suspect of that sensor and connection. If I could, I'd go back and just get the one weth the OE connector. My paranoia has not been worth the $50 saved.
Question Reality.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6388 MB (Peak: 0.7582 MB) Data Comp: Off Server Time: 2026-05-29 23:50:23 UTC
