Page 1 of 4 1 2 3 4
Common Toyota Problems, Post yours... #876329 03/19/08 08:05 PM
P
PETE_YK Offline OP
Thought i would start a post regarding common toyota problems, not anything major just the little things like sticky seat belts, vents that wont stay open etc. ...rust <img src="/forums/images/graemlins/lol.gif" alt="" />haha. this is just for fun, feel free to add...
88' Xtra cab, 22RE, 5 spd, alumi flat deck, 3" BL, 35" muds...awaiting SAS.
'02 Ram, 4.7, REV 'Shooter' wheels wrapped with M.T. Baja claws.
Re: Common Toyota Problems, Post yours... [Re: PETE_YK] #876330 03/19/08 08:25 PM
V
v8yota Offline
93 xcab,,,speedometer does not work
Re: Common Toyota Problems, Post yours... [Re: v8yota] #876331 03/19/08 10:21 PM
G
Greg_Canada Offline
squeeky speedo.
blown 3.0 exhaust manifold gaskets
leaky 3.0 valve cover gaskets
whiney rear diffs
broken/cracked heater controls sticker
unreliable rear tailgate window (i think i've finally got it 100%)
89 4Runner
Re: Common Toyota Problems, Post yours... [Re: Greg_Canada] #876332 03/19/08 10:23 PM
Adam F Offline
88 4R V6
Cruise control quit working
Rear window motor randomly quits working
Door locks freeze up in winter
97 4R V6
Rear hatch and rear door door pin switch sticking, dome lights dont come on some times
Very little air flow from the passenger side vent
Every windsheild wiper blade I put on, it smears the water
Keyless entry remote range sucks, replaced battery but no change. Only works 10 feet away or less.
96 Rav-4
Rear washer fluid sprayer inop. Hose disconnected somewhere.
Timer off function on rear defrost inop. Never turns off unless you turn it off manually.
97 4R, stock, daily driver
Re: Common Toyota Problems, Post yours... [Re: Adam F] #876333 03/20/08 12:16 AM
G
Greg_Canada Offline
Hey Adam have you tried PIAA Supersilicon wiper blades? I had the same problem on my 89, put these on, and it's been MINT since... expensive but well worth it... burtman sells them.
89 4Runner
Re: Common Toyota Problems, Post yours... [Re: Greg_Canada] #876334 03/20/08 01:10 AM
Adam F Offline
Havent tried the PIAA, but I did buy some $15/blade Michelin's that are the newer curved shape, and those still streak in the middle. I think theres something wrong with the wiper arm itself. Either the spring is weak or its bent. I'm going to price out a brand new arm at the dealer....wish me luck <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Common Toyota Problems, Post yours... [Re: Adam F] #876335 03/20/08 05:46 AM
mama Offline
Always something else to do with it that costs money/time <img src="/forums/images/graemlins/mrt.gif" alt="" />.
90 toy
dx
Acura seats and almost perfect matched paint.
Re: Common Toyota Problems, Post yours... [Re: PETE_YK] #876336 03/20/08 07:46 AM
TRDSR5 Offline
#1 common problem across all Toyota models dating way back has to be that at some point they will lose low speed on the heater/blower <img src="/forums/images/graemlins/cheers.gif" alt="" />
Turn LEFT to go RIGHT
Thudump!....What was that daddy? Ran over a Honda, go back to sleep sweety.
Re: Common Toyota Problems, Post yours... [Re: TRDSR5] #876337 03/20/08 02:30 PM
Jeff G 89 Offline
How about the turn signal stalk contact noise? Both my PU and 4R sound like an old pinball machine with a bad flipper if I don't fully engage the left or right signal. It usually happens on lane changes when I use the momentary switch.
The non-retracting seatbelts are very annoying along with the speedo squeal at low temperatures.
Another is the driveshaft clunk in 4Runners and auto trans PUs. Just before a stop, the plunging part of the driveshaft sticks and then releases creating a loud clunk and jolt. Frequent lubing helps a bit, but doesn't stop it.
Other than these annoying little problems, my trucks have been rock solid <img src="/forums/images/graemlins/kewl.gif" alt="" />
'89 Toy 4x4 Xtra Cab SR5 V6 266k miles
'01 Tacoma 4x4 Xtra Cab 2.7L
'97 Toy 4Runner Limited
Re: Common Toyota Problems, Post yours... [Re: Jeff G 89] #876338 03/20/08 05:26 PM
Scerb Offline
Other than the fact that everything breaks with big tires.. <img src="/forums/images/graemlins/shiner.gif" alt="" />
A few things I have noticed on truck that are 15+ years old, is the horn contacts wear out, clutch slave cyls fail, all sorts of bulbs die, seatbelts dont retract, pinion seals, wheel bearings... again thats after 15-20 yrs so pretty much any vehicle will have these problems over that many years.
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6412 MB (Peak: 0.7608 MB) Data Comp: Off Server Time: 2026-07-15 00:22:29 UTC
