Page 2 of 4 1 2 3 4
Re: Common Toyota Problems, Post yours... [Re: TRDSR5] #876339 03/20/08 07:06 PM
RatLabGuy Offline
Now, I interpereted the point of this trhead a little differently - the little problems that are common on these vehicles, that we see posts about all te htime and after awhile you come to expect them.
These are the little things that are clear failures in engineering (not just teh usual random old truck things) that somebody might not have anticiptaed 20 years ago.
For example, the crack in the passenger side dahspad that appears just to the right of the center console area. I have yet to see a vehicle w/o evidence of this happening. (due to the bolt stud underneath it btw).
Or the intermittent high beams from worn contact in the steering column console.
#1 common problem across all Toyota models dating way back has to be that at some point they will lose low speed on the heater/blower <img src="/forums/images/graemlins/cheers.gif" alt="" />
Great example - mine's missing it too!
Others:
If you throw a rod bearing, it will be #2
Crappy contacts or worn motor in rear window
UNDERheating due to bad thermostat
hub cone washers stuck to all h$ll
Saggy rear leaf sprigs
etc etc
Question Reality.
Re: Common Toyota Problems, Post yours... [Re: RatLabGuy] #876340 03/20/08 07:56 PM
G
Greg_Canada Offline
oooohhhh how could i forget... squeeky steering stops! That make that godawful sound on the 86-95 IFS!!!...
89 4Runner
Re: Common Toyota Problems, Post yours... [Re: Greg_Canada] #876341 03/20/08 08:32 PM
5
5150 Offline
E-brake sticks on if not lubricated every fall before winter. Steering column has a squeak and lots of front brake calipers to name a few. Still very hard to hurt this truck even if you try....tough
Re: Common Toyota Problems, Post yours... [Re: Adam F] #876342 03/21/08 11:50 AM
4xJedi Offline
Havent tried the PIAA, but I did buy some $15/blade Michelin's that are the newer curved shape, and those still streak in the middle. I think theres something wrong with the wiper arm itself. Either the spring is weak or its bent. I'm going to price out a brand new arm at the dealer....wish me luck <img src="/forums/images/graemlins/scared.gif" alt="" />
Try this before buying a new arm. Bend the last three inches or so of the wiper arm down towards the windshield. You can usually do it with your hands then set the arm and blade back on the glass. This puts more pressure on the center of the blade and will take care of any 'light pressure spots' which usually causes streaking (if you don't have crappy blades).
'86 4Runner 5" SAS
'97 4Runner
'05 Corolla
'00 F250 PowerStroke
Re: Common Toyota Problems, Post yours... [Re: PETE_YK] #876343 03/21/08 11:34 PM
P
Pyroboy Offline
I've had rust problems with my A-pillars since new. I finally cut the roof off a wrecked truck and need to get the pillars cut out and replaced.
Had to replace the heater blower motor resistor twice.
Rear window regulator needs to be lubed yearly to keep it working well.
After 285,000 miles, not really much to complain about!
1989 4Runner Special Edition
22RE, 5-spd.
TG 3" SAS, MC DuaLs, 4.56s, Air Locker
Hi-Clearance panels by
www.toyotafiberglass.com
Re: Common Toyota Problems, Post yours... [Re: Pyroboy] #876344 03/22/08 01:29 PM
Bigbluemax Offline
I also had a # 2 rod knocking, pulled the oil pan, replaced the bearings, been running good for 2 years.
Seen a couple broken birfields in the pre 85 trucks. Bought longfields and have not had a problem since.
Seat belts do not retract.
Doors get bent up when 4 wheeling.
But I have seen a lot more jeeps broken down than Toys!!
New project, 1985 4x4 SR5, EFI Solid axle 5.29 welded, exo cage 4" lift 37" Boggers.
2001 Chevy HD,CC,4X4,Duramax diesel puller.
Re: Common Toyota Problems, Post yours... [Re: Bigbluemax] #876345 03/22/08 01:36 PM
Billydkid Offline
22r tensioner pulley bearing.
93 4runner V6, 4.88's, 31" mt's with more to come.
03 Tundra V8 on 265's
Re: Common Toyota Problems, Post yours... [Re: Billydkid] #876346 03/22/08 05:36 PM
toyomorph Offline
+1 on seatbelts not retracting
canyon country explorer
1993 4x PUP
Re: Common Toyota Problems, Post yours... [Re: toyomorph] #876347 03/24/08 05:15 AM
DRTDEVL Offline
I can't keep a license plate light in my 87 4Runner... Don't know why, but the bulbs rarely last more than a year.
Saggy butt. Got it.
Frozen door locks... Not the lock cylinder itself, but the linkage inside the door. I have yet to find the fix.
L/S HVAC vent refuses to stay open... Hit a bump... *click* goes the door slamming shut inside.
L/S wing vent window latch is wore slap out... I have a 10 cent euro piece in there to take in the slack.
Exhaust manifold leaking. Again.
Corrosion in wiring harness areas: Injector splice, Alternator charge circuit splices by battery.
Passenger window motor intermittent since I bought the rig 10 years ago.
FREEKING COOLANT TEMP GAUGE HAS A MIND OF IT'S OWN!!!!!
Re: Common Toyota Problems, Post yours... [Re: DRTDEVL] #876348 03/24/08 02:36 PM
G
Greg_Canada Offline
Oh oh, vent window...
I had the same problem as you... then i realized my frame was rotten, and the seal was bad.
I replaced the frame and seal with no rusty parts from down south, and it works great (still lets water from a pressure washer in tho DOH....
89 4Runner
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6433 MB (Peak: 0.7686 MB) Data Comp: Off Server Time: 2026-07-16 03:39:38 UTC
