HELP! Kia's dead #876375 03/19/08 09:06 PM
Z
Zarniwoop Offline OP
That'll teach me to question it's power output.
My wife was driving it yesterday when it just peacefully died, no splutter or smoke just cut out at the lights and it won't start again.
The only clue I have before I start working on it today is that there is a slight buzzing sound coming from the air intake control valve and it stops when I remove the connector to the valve, doesn't help start it but it's the only thing I have right now. Any ideas?
Cheers
Andrew
Re: HELP! Kia's dead [Re: Zarniwoop] #876376 03/19/08 09:48 PM
Yankee_Tim Offline
Will it turn over? If so, timing belt?
Yankee Tim
Re: HELP! Kia's dead [Re: Yankee_Tim] #876377 03/19/08 10:07 PM
Z
Turns over but I can see the cam shaft moving when I remove the oil filler cap - actually the shaft itself appears to be moving but the rockers aren't?
No check engine light, just filled with fuel to ensure the fuel gauge didn't have gremlins, will post more info when available...
Re: HELP! Kia's dead [Re: Zarniwoop] #876378 03/19/08 10:36 PM
Iron Offline
If the cranks moving and the rockers are not, timing belt! Take of the cover to see for sure!
08' Jeep Wrangler
64' Plymouth Sport Fury 383
58' Triumph TR-3A
Re: HELP! Kia's dead [Re: Zarniwoop] #876379 03/19/08 10:40 PM
Lou Offline
..60k km when you bought it 2 years ago....so now, what does the "clock" show.?
What you describe has been told in same words several times here and timing belt was the culprit quite often...so I'd check for those cams...what you say is strange...pull the T-belt cover http://www.geocities.com/lmp4203/kiasport/timingbelt.jpg and make sure this issue is cleared out first before looking for other oddities.
The word is change the belt before 70,000 miles, that is 110k km...I'm about to go by that rule.
Otherwise....is the CEL ON?
..and yeah...Sporty has a temper....!
Re: HELP! Kia's dead [Re: Lou] #876380 03/20/08 01:27 AM
Z
Dammit! Timing belt is ok, onto the fuel system...
Re: HELP! Kia's dead [Re: Zarniwoop] #876381 03/20/08 03:01 AM
Lou Offline
There are fuses and 2 relays under the hood. Both are similar..but both must work for the fuel pump to work.
www.geocities.com/lmp4203/kiasport/FuelPumpCircuit.jpg
Try to hear the pump buzz for 1-2 sec at KEY ON... fold down the rear seat and remove the cover for access to the top of fuel tank. YOu an take a voltage measurement there at the pump connecetor is pump does not buzz.
Re: HELP! Kia's dead [Re: Lou] #876382 03/20/08 03:25 AM
Z
Ok now I think I have a problem, I checked over the electrical system for the fuel pump and I'm getting 12V at the connector without any issues and when I remove the fuel line from the filter and turn the engine I don't get any fuel coming out. So the fuel pump looks a little suspect.
Having nothing better to do I decided to remove the fuel pump and try and power it on the bench but after I removed the cover under the back seat I find that the fuel pump is actually further forward than the inspection hatch (if you look directly into the hatch you can only see about 1-2 inches of the top of the fuel pump and it also doesn't have any screws on top of it. It's a plastic top with a series of grip points on it that almost looks like it should unscrew but it won't unscrew by hand and I'm a little hestitant to start getting aggressive with it until I know it can be unscrewed.
Has anyone come across this before?
(BTW long body version)
Cheers
Andrew
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6204 MB (Peak: 0.7029 MB) Data Comp: Off Server Time: 2026-11-02 20:02:35 UTC
