Steering Gear #876805 03/22/08 06:16 PM
8
85Montero Offline OP
Hi all,
I have a leaking steering gear seal I need to replace. I have about killed my puller to no avail on the pitman arm. Its not rusted so I havent gotten out the torch. Anyone who has pulled a pitman arm have any suggestions on seperating the pitman from the steering gear? Ive banged down on it with a sledge too.
Thanks
Re: Steering Gear [Re: 85Montero] #876806 03/22/08 08:20 PM
KrzyDav Offline
1st ,I would bang on it.
I had to get the right puller. A big black OTC from Taylor rental. 2 6 in. jaws with bolts between to keep from popping off. Tighten it a bit , soak with P-blaster, tighten a little more, let it sit under tension for an hour or two, tighten some more. If you realy have to , tap here a there with a small ball pien. A PITA , patients, and good luck.
dave h.
Re: Steering Gear [Re: KrzyDav] #876807 03/22/08 11:12 PM
I fixed mine with PS fluid with stop leak, about 80K miles ago...
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5932 MB (Peak: 0.6473 MB) Data Comp: Off Server Time: 2026-06-07 06:08:26 UTC
