Re: 2.6 Carb problem [Re: krenzy] #876838 03/28/08 01:50 PM
toddstidham1 Offline
Being an 89...maybe they kept giving you parts for the 3.0L V6 instead of the 2.6L 4cyl? All Montero's/Raider's are all the same as far as parts...the only difference between the two are the badges and some paint.
The reed valve is an air injection for the catalytic converter...it works on negative pressure exhaust pulses to draw air into the exhaust. If you have exhaust coming out of yours then it needs to be replaced. I'd get one from a junkyard to save money.
The cable is adjustable to compensate for stretch/slack. There is a bolt that holds the cable housing to the valve cover and the housing is slotted. You can loosen the bolt then gently pull the housing away from the carb to tighten up the cable action (although you want some slack so you can lower the idle speed if necessary).
If the choke is not opening, first try some spray carb cleaner and move the choke plate by hand to make sure it's able to move freely (you may need to hold the throttle open slightly in order to move the choke plate). As the engine warms it should slowly open on it's own. It can be adjusted, but that requires drilling out the three rivets on the choke assembly and replacing them with screws, then you can rotate the choke housing to increase/decrease choke spring tension.
Your whole problem could be the choke, flooring the throttle usually cracks the choke plate open, try holding it open with a big or t-handled screwdriver (so that it can't fall down into the carb) and see if it'll start to idle. Another thing to check is if the carb is dumping fuel while running. Mine did this and it looked like a waterfall of gas just running down into the primary throttle bore and when you turned off the engine you could hear it gurgling and trickling down into the engine (as well as see it by holding the choke plate open). Stuck float inside the carb was the cause.
Finally, the FSM has the best information for diagnosing the carb. There are tons of links within the forum to download them and McMontyV has a link in his sig.
-Todd
1987 Montero 2.6l 5-speed (Sold...but I still miss her)
2008 Jeep Patriot Sport 4x4
Re: 2.6 Carb problem [Re: toddstidham1] #876839 03/28/08 11:44 PM
E
EyeOnCy Offline
Another note to add is if you keep that carb and get it running right it will run a decent sum more rich from what I hear. Theres a shop in town that actually has plenty-o'experience on the Mikunis. They told me a few things before I mentioned having a Weber, one of which is the Mikunis supposedly run a little bit more rich. Yes I know its better to run rich than lean and its probably more common on carb engines, but they said its very very difficult to get it close to mid. I can't remember they're explanation why...hope thats of some use later.
1989 Dodge Raider 2.6L/5spd
2004 Honda Element EX
1989 Dodge Daytona Shelby Z
1993 Toyota P/U
Re: 2.6 Carb problem [Re: EyeOnCy] #876840 04/10/08 09:17 PM
G
Grizzly Offline
Can you help me with my new weber carb?
I already install the carb, but I`m lost how to connect all the vacuum lines.
Can you send me your e-mail and I can send you some photos to compare with your montero/raider?
Thanks
Baruch
Re: 2.6 Carb problem [Re: Grizzly] #876841 04/15/08 04:14 PM
E
EyeOnCy Offline
Who are you referring to? ME? If so my email is Shelby87cc@aol.com, I don't check the forum a whole ton, but I check email regularly. I may not be loads of help w/ the Mikuni setup since I just absolutely hate it. I can help w/ Weber though.
1993 Toyota P/U
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6090 MB (Peak: 0.6829 MB) Data Comp: Off Server Time: 2026-05-29 23:56:27 UTC
