91 Jeep Wrangler engine #876849 03/22/08 10:49 PM
skip234 Offline OP
I have come across a 91 Jeep Wrangler with a blown 6 cyl. engine. I want to replace the engine. What year engines can I put in this Jeep without alot of rework?
Re: 91 Jeep Wrangler engine [Re: skip234] #876850 03/23/08 01:48 PM
E
el_d_m Offline
you can put the stock motor back in or you can get a stroker that uses the same block & head. there are kits that will allow you to put chevy v8's in her. i would suggest sticking with the stock block just build her up.
check ebay & search "4.0 stroker". give you a rough idea
93 xj stroked 4.2 w/4.0 head avenger supercharged 6.5" long arm 35" buckshots rubicon 44's front & rear
Re: 91 Jeep Wrangler engine [Re: skip234] #876851 03/23/08 03:14 PM
F
Fred Blackstone Offline
6 cyl 4.0L Jeep engine is more than adequate for the YJ Wrangler, especially offroad; IMO there is no need for installing a V8 or any other engine. The expense of swapping your 4.0L for a different engine is difficult to justify. It's difficult to beat the original 4.0L engine that evolved during the late 80's and early 90's. Economically, it would be best to repair the existing engine, if possible. If it isn't possible, I'd recommend replacing the engine with another 4.0L Jeep engine.
So, what's wrong with the "blown" engine, specifically? Can it be easily repaired?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5923 MB (Peak: 0.6448 MB) Data Comp: Off Server Time: 2026-05-29 23:58:42 UTC
