What VIN code for LS differential #876911 03/23/08 11:57 AM
tomjarz Offline OP
I'm new to to this wesite. Just bought a 1990 trooper with a 2.8 v6 and auto tranny, I believe it's a 4L30E. I would like to know if anyone out there knows if you can determine if you have a factory limited slip diff. from your VIN. If so which number would that be? Tried doing a search, the info is probably allready on this site somewhere but I didn't find it. Thanks for any input. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: What VIN code for LS differential [Re: tomjarz] #876912 03/23/08 01:36 PM
Van Offline
Welcome to the site..... short answer, no, not on the VIN.... but look at your build options code plate (engine compartment firewall?) for G80, that'll indicate LSD.
HTH
Van <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
P.S. Theres a link to all the option codes for Troopers on "ITOG" ... main page no longer works and I've got the link on the other computer... will paste later.
'94 Isuzu Pickup, 4x4
NEVER give up...
Re: What VIN code for LS differential [Re: Van] #876913 03/23/08 01:56 PM
tomjarz Offline OP
Thank you Van, I checked the options plate and no G80. you wouldn't happen to know the gear ratio and wether ther is a shim installed on the ring gear? Original tire code is 9MV. <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: What VIN code for LS differential [Re: tomjarz] #876914 03/23/08 03:47 PM
Van Offline
Here's the link, but main site is dead....
http://www.zitog.com/xr-001.shtml
NEVER give up...
Re: What VIN code for LS differential [Re: Van] #876915 03/23/08 05:07 PM
Jim_Paget Offline
Unless you happen to have a fairly rare Trooper, your axle ratio is 4.56.
If your rig has around 200K on the speedo, there is a pretty good chance that even if you have a LSD, it is now toast. The clutches wear out, and there are more cost effective ways of addressing the issue than rebuilding a worn out LSD.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: What VIN code for LS differential [Re: tomjarz] #876916 03/24/08 01:08 AM
JLEMOND Offline
THAT TIRE CODE IS FOR 235 X 70 R 15 WHICH MEANS AS JIM STATED YOU HAVE A 4.55 REAR AXLE. JERRY
Re: What VIN code for LS differential [Re: JLEMOND] #876917 03/24/08 02:05 PM
tomjarz Offline OP
Thanks again everybody. Great website!! <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6145 MB (Peak: 0.6930 MB) Data Comp: Off Server Time: 2026-06-20 23:00:48 UTC
