frame rust with rear shock mount problems #876988 03/24/08 04:25 AM
Sid's Toy Offline OP
been a long time. My runner has been dormant for a while but I finally got it back on the road again. I took it light wheeling to see if all the bugs were worked out. it was great but found new problems to fix. i'm starting to wonder if I should find another project truck to work on and swap what i have into another truck.
The biggest problem is the drivers side frame rail has major rust holes - start about where the frame curves up in the rear wheelwell, inside and outside of the frame rail. When I got back from wheeling, i checked the rear shocks and the driver's side (brand new) rear shock had ripped out the top frame mount and bent the threads for the shock. The rear end is very loose.
My question is can I relocate the rear top shock mounts. I looked breifly but it looks like the panhard rod and mounts would get in the way. does anyone have any other advice.
i would love to contnue to drive this truck but don't have the time for a body off restoration. the passenger side frame rail is solid, just the driver side rear is shot, but its shot pretty good.
cheers
sid
92 4Runner SR5 3.0 standard tranny
4.88 gears, rear elocked, OME coils, SAW Tbars, allpro rock sliders and rear bumper, custom made front, downey v6 headers ...
Re: frame rust with rear shock mount problems [Re: Sid's Toy] #876989 03/25/08 04:46 PM
fourwd1 Offline
How about adding a cross member and doing it like this
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: frame rust with rear shock mount problems [Re: fourwd1] #876990 04/05/08 12:48 AM
i could do something like that but i need good metal to weld to. i'm afraid there is hardly any good metal back there on that side.
has anyone cut out 1/4 of a frame rail and welded a new peice on. sounds like alot of work and i dont have the skills, welders, grinders, etc., just wondering what my options are.
anyone know someone in central VA willing to help a friend out.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5931 MB (Peak: 0.6469 MB) Data Comp: Off Server Time: 2026-10-24 03:22:23 UTC
