sportage rims #877165 03/25/08 08:54 AM
O
oul053 Offline OP
i bought some 31in tyres the other day and rang up to get some rims today and they told me that they were a front wheel drive offset. i read in the post about wheels from an f 150 would fit, so does that mean the steelies from an f150 would also fit or do they have different offset. i can get some rims but they have a patrol or landcruiser offset and im worried that the tyres will sit outside the guards or rub on suspension.
01 sporty, king springs,235/75/15s,tjm nudge bar,narva blue spotties,triffa spotties,uhf,dual battery sys and a sub.
Re: sportage rims [Re: oul053] #877166 03/25/08 09:39 AM
DamKia Offline
Kia Moderator
http://www.4x4wire.com/forums/showf...amp;amp;sb=5&o=7&fpart=1
Read and absorb....
Be prepared for a bit of panel work.
Re: sportage rims [Re: oul053] #877167 03/25/08 09:53 AM
4
4runnernomore Offline
Try finding out what Ads is running on his. He may be able to help.
I can't remember if it was on 4WD monthly or Down under 4x4 where he mentioned what rims he was running.
Cheers, Chris
97 Sporty, snorkel, K&N filter,chipped, ext forks, 40mm Dob Springs, KYB struts, 35mm Jeep TJ Springs, RAV 4 OME shocks, Kaiser Locker 5.38 R&P's, 1&3/8 body lift, 245/75 R16 D674's Sports steering wheel, bullbar, extractors & 2 1/4 exhaust engineered.
Re: sportage rims [Re: 4runnernomore] #877168 03/25/08 10:41 AM
DamKia Offline
Kia Moderator
If they are like mine they are the steel 15 x 7 F150/Bronco 4x4 rims with a +7mm offset. Gives a backspace of about 4.5"
Re: sportage rims [Re: DamKia] #877169 03/25/08 02:29 PM
Lou Offline
JUst to mention CHevy Tracker steel wheels will fit direct..I have them...they are just 3/8" offset outwards more than the original KIA , but they are not "oversize" though.
Re: sportage rims [Re: oul053] #877170 03/26/08 05:26 AM
DennisThompson Offline
Most factory Ford wheels will not fit. The center hole is to small. Before you buy some measure to make sure. I carried a spare tire for 2 years before I found out it would not fit over the hub, I'm just glad I didn't find out the hard way.
Dennis
Re: sportage rims [Re: DennisThompson] #877171 03/26/08 08:42 AM
O
oul053 Offline OP
so with the +7 offset do they sit outside of the guards with 31's. i have already lifted it so thats no big deal.
Re: sportage rims [Re: oul053] #877172 03/26/08 06:08 PM
DamKia Offline
Kia Moderator
31 x 10.5's sit just outside the guards (1/2 in or so), even with (what remains of) the original plastic guard extensions on the longies.
Re: sportage rims [Re: DamKia] #877173 03/26/08 06:25 PM
Nukeiridium Offline
If you can manage it, 31's look extremely good on a Sportage, I must say. I ran them on my old Sportage. Just my 2 cents. They really change the look of the vehicle.
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: sportage rims [Re: Nukeiridium] #877174 03/28/08 08:51 AM
O
oul053 Offline OP
well i got 235's on standard alloys now which makes it look alot better so 31's can only help it. <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6294 MB (Peak: 0.7360 MB) Data Comp: Off Server Time: 2026-05-29 16:39:02 UTC
