95 SR engine removal top bell housing bolts?????? #877264 03/25/08 09:34 PM
coletrain777 Offline OP
Hey guys,
How in the world do you guys get to the top two trans to engine bolts (bellhousing bolts) on a 3.5 Gen 2. I wouldn't think that an elf could fit his hands up behind the motor between the firewall and the block. I was planning on having the motor out of my donor SR today, but I am almost ready to take the torch out and do some cutting (please don't let that happen). I have unbolted the motor mounts from the block in order to allow the engine to drop down a little, but that ony gave me about 1/2 an inch. What's the trick here? On most vehicles like this there is an access cover that you unbolt from inside the cab that allows you to access these bolts, but I sure don't see one on the Monty. HELP!!!!!! My wife is ready to drive her SR for the first time, and I am ready to sell the Navigator that it is replacing (pay off some bills <img src="/forums/images/graemlins/smile.gif" alt="" />). Any ideas... Thanks Cole
95 Monty Sr 3.5
1973 Datsun 240Z
1972 240z roadster
1969 Ford F-100 shortbed
1972 Ford F-100 longbed
1976 Ford F-250 longbed
1994 Jaguar xj6 vandenplas
2001 Lincoln Navigator
2002 Ford ZX2
Cole
Re: 95 SR engine removal top bell housing bolts?????? [Re: coletrain777] #877265 03/25/08 09:40 PM
NathanC Offline
I reached 'em by stooping over the engine and reaching down from above with a box end wrench. Wear gloves. <img src="/forums/images/graemlins/shiner.gif" alt="" />
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: 95 SR engine removal top bell housing bolts?????? [Re: NathanC] #877266 03/25/08 10:07 PM
I will go out and give it a try. I am pretty sure I can get the passenger side like that, but the driver side doesn't even look like it has room to get a wrench in there, let alone a big paw like mine (my hands are pretty big <img src="/forums/images/graemlins/frown.gif" alt="" />. Anyway, I'll go give it a try. If that doesn't work any other ideas???
95 Monty Sr 3.5
1973 Datsun 240Z
1972 240z roadster
2002 Ford ZX2
Cole
Re: 95 SR engine removal top bell housing bolts?????? [Re: NathanC] #877267 03/25/08 10:09 PM
monte Offline
I've never pulled the whole block out, but when I took the heads off, they are sitting right there...
Otherwise, I couldn't imagine what a pain in the arse it must be to get to... but then again.....
Almost everything designed on the 2nd Gen 3.5 is <img src="/forums/images/graemlins/barf.gif" alt="" />
Pull the heads off first if you can.
Re: 95 SR engine removal top bell housing bolts?????? [Re: monte] #877268 03/25/08 10:32 PM
At least take the intake off. I used long extensions for the drivers side, I think. Box on the pax side.
I did not particularly like that portion of the job. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 95 SR engine removal top bell housing bolts?????? [Re: NathanC] #877269 03/25/08 11:57 PM
If you can't reach it, then perhaps you could R&R the engine and tranny then put the tranny back. <img src="/forums/images/graemlins/shiner.gif" alt="" /> CAP510 might have more insight since he's been all over this with his 95/94SR.
Re: 95 SR engine removal top bell housing bolts?????? [Re: OldColt] #877270 03/26/08 07:31 AM
mxmikie Offline
jack the back of the transfer case up
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6192 MB (Peak: 0.7103 MB) Data Comp: Off Server Time: 2026-06-20 19:18:36 UTC
