AMC head #877321 03/25/08 11:52 PM
binx Offline OP
I installed an AMC head recently and after a couple hundred miles took out the plugs to put in some higher end ones and noticed all four plugs were gunked up. so i checked the oil and noticed it was loosing a lot, where it had never before. Just curious if anyone else has had problems with these heads or if maybe something was done wrong on the install? mostly if there is anything i can do to fix it.
thanks
2000 amigo ironman, 4" suspension 1" body lift on 33's with 4.77 gears, tera lows, and no-slip locker.
Re: AMC head [Re: binx] #877322 03/26/08 04:47 PM
Trooper-san Offline
I've had an AMC head on my 2.6 Trooper for maybe two years now. I have had absolutely no issues with it. I should have put it on long ago.
I think your problem lies with the install, some error, or perhaps is a totally separate problem, nothing to do with the AMC head or the installation. Start by looking at the gunk. What kind of gunk is it?
1989 Trooper, 2.6
1989 Trooper, 2.8
1992 Ford F-350, 7.3
My Photos
Re: AMC head [Re: Trooper-san] #877323 03/26/08 08:47 PM
binx Offline OP
it is black and moist looking, i just assumed it was burnt oil. it is using about a quart every 300 mi.
From what i know either all four rings went bad when the new head was put in or the head came with bad seals, but i am no expert for sure. I am hoping its just something to do with the install, but of course it probably isn't
PHP: 7.4.33 Page Time: 0.718s Queries: 15 (0.005s) Memory: 0.5962 MB (Peak: 0.6495 MB) Data Comp: Off Server Time: 2026-10-24 08:18:42 UTC
