Re: Location of OBD connector [Re: bombardj1] #877368 03/27/08 08:46 AM
A
Andrew_Main Offline
Yep had back pressure in the fuel system. Also have 12 volts at the injectors.
Re: Location of OBD connector [Re: Andrew_Main] #877369 03/27/08 01:56 PM
Hydra747 Offline
Did you ever find the obd connector??
What code reader did you buy?
---Mike <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Location of OBD connector [Re: Zarniwoop] #877370 03/27/08 02:03 PM
bombardj1 Offline
you said timing belt is ok how many miles on it ? maybe it jumped a few gears I would pull bak cover and see if both the marts line up
Re: Location of OBD connector [Re: bombardj1] #877371 04/10/08 08:01 AM
Hydra747 Offline
Status?
Update?
<img src="/forums/images/graemlins/confused.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6087 MB (Peak: 0.6811 MB) Data Comp: Off Server Time: 2026-06-07 06:57:31 UTC
