front diff (rear) question #877501 03/26/08 11:59 PM
V
v8yota Offline OP
hi,, i just bought 4.88 rear 3rd anda front rear,,,my question is the front rear had the ADD and i am putting it in a 93 toyota truck with lock out hubs,,,can i take the driver side tube with the ADD off and replace it with the tube that is on my rear that is in the truck now,,,the driver side tube that i am talking about has 4 bolts holding it on,,,,thanks in advance
Re: front diff (rear) question [Re: v8yota] #877502 03/27/08 01:37 AM
Jake97T Offline
im confused?!? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: front diff (rear) question [Re: Jake97T] #877503 03/27/08 02:31 AM
V
v8yota Offline OP
the tube that bolts to the pumpkin on the front rear,,,the tube has the ADD mounted to it,,
Re: front diff (rear) question [Re: v8yota] #877504 03/27/08 05:26 AM
OOP'S Offline
Yes !!!!!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: front diff (rear) question [Re: v8yota] #877505 03/27/08 05:28 AM
ToyinAround Offline
Front diff is a better term so u dont confuse people. I suppose u could switch tubes? or u could just disable the ADD on the new diff.
1987 4Runner SR5,SAS,6 inches of lift,35in BFG's,Welded Front,Detroit E-Z locker V-6 Rear, 5.29's
Re: front diff (rear) question [Re: ToyinAround] #877506 03/27/08 05:33 AM
OOP'S Offline
It will be stronger with out it and it is a plug and play swap.
David Fritzsche
Roseville, CA
Re: front diff (rear) question [Re: OOP'S] #877507 03/27/08 06:22 PM
grandeyota Offline
Almost plug and play. Need an oil seal to replace what the ADD had in there in order for that non-ADD part to fit. Toyota part number 90311-35032
Fur clog in the sausage grinder
Re: front diff (rear) question [Re: grandeyota] #877508 03/28/08 03:02 AM
P
Pyroboy Offline
Where does the seal go?
I've got he same problem; bought a used front centre section that was in an ADD truck and I have manual hubs. It sounds like the left side tube off the non-ADD section is a bolt-on replacement for the ADD and shorter tube? Are there any other gaskets or parts to replace while it's apart?
1989 4Runner Special Edition
22RE, 5-spd.
TG 3" SAS, MC DuaLs, 4.56s, Air Locker
Hi-Clearance panels by
www.toyotafiberglass.com
Re: front diff (rear) question [Re: Pyroboy] #877509 03/28/08 03:27 AM
OOP'S Offline
David Fritzsche
Roseville, CA
Re: front diff (rear) question [Re: Pyroboy] #877510 03/28/08 03:34 AM
grandeyota Offline
This seal is the only one I replaced. The ADD diff had a gear or something in there instead of that seal. That part had to come out. The seal went in where that gear came out of.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6289 MB (Peak: 0.7360 MB) Data Comp: Off Server Time: 2026-10-24 13:52:43 UTC
