Sway bar #877593 03/27/08 04:42 AM
mama Offline OP
Is the sway bar worth keeping? I have the bushings and the bolts to remount it but it will take me a while to drill and retap the holes where the old bolts broke off. I know it reduces articulation but I don't run in to to many problems on the road and the occassional mud puddle.
Any feedback would be worthwhile.
90 toy
dx
Acura seats and almost perfect matched paint.
Re: Sway bar [Re: mama] #877594 03/27/08 04:45 AM
kewlynx Offline
It's dodging deer and little kids that gets you in trouble. Consider a swayaway setup. Couple reviews here.
http://www.4x4wire.com/toyota/reviews/
**ubi apis- ibi salus**
Re: Sway bar [Re: mama] #877595 03/27/08 04:46 AM
4Crawler Offline
If you don't have any issues on the road, may as well ditch it. Read the page below for a little decision process discussion and see what works best for you:
http://www.4crawler.com/4x4/CheapTricks/SwayBar.shtml#AreTheyForMe
I've been w/o a front sway bar for about 10 years now, since I had crossover steering installed. Leans a little more in turns, but you get used to that after a while. I found my truck actually handled better w/o the sway bar, but YMMV.
Re: Sway bar [Re: mama] #877596 03/27/08 06:27 AM
Snowtoy Offline
Really depends on driving style, width of tires, and torsion bar settings. A buddy of mine ran a set of BFG 365's(equivalent to a 31x12.50), on 15's with 1" lift set in for the T-bars, and it cornered well enough w/o the sway bar.
If you corner hard like I do in my '90 than you would want to keep the sway bar, I actually increased mine by adding poly bushings, basically doubling the size of the bar.
Re: Sway bar [Re: Snowtoy] #877597 03/27/08 06:47 AM
IceBlueT Offline
i've run mine without a sway bar for a little over a year now, and i havent seen any problems so far. i do wheel alot while im at school, but i also have to drive the truck 500 miles every month or so. like they have said above, it all depends on your driving style and what you do with the truck.
formerly 277000_yota
Old enough to know better, but still to damn arrogant to care...
]www.cardomain.com/ride/2614269
'90 'Yota 4X4 (10/31/05-09/10/08 R.I.P)
'98 'Yota t-100. 3.4, 5 sp. 4x4, 2 in. Toytec with BFG A/T 265/70R16s
Re: Sway bar [Re: IceBlueT] #877598 03/27/08 07:15 AM
G
Greg_Canada Offline
Mine sways alot with the sway bar, i'd hate to feel it without... i'm actually going to put thicker swaybars on front AND rear for DD'ing...
89 4Runner
Re: Sway bar [Re: Greg_Canada] #877599 03/27/08 02:59 PM
RatLabGuy Offline
Is there a rear sway bar? I've never noticed one.
I've been w/o it for about 3 years also. Not my DD, but used mostly on-road. Hardly noticed a difference when I took it off.
I'd think it'd be less of an issue if you have the t-bars really cranksed already too
Question Reality.
Re: Sway bar [Re: RatLabGuy] #877600 03/27/08 04:46 PM
4Crawler Offline
Addco makes a rear sway bar for the pickups and leaf spring 4Runners.
Re: Sway bar [Re: mama] #877601 03/27/08 06:16 PM
P
PETE_YK Offline
Ditched the sway bar on both my trucks, never looked back.
However...the dd has rancho 5000s all around which ride like a sack of frozen dog ***** while my 87 clunker has monroes and it does lean a bit.
88' Xtra cab, 22RE, 5 spd, alumi flat deck, 3" BL, 35" muds...awaiting SAS.
'02 Ram, 4.7, REV 'Shooter' wheels wrapped with M.T. Baja claws.
Re: Sway bar [Re: PETE_YK] #877602 03/28/08 01:49 AM
Buck Offline
I've been thinking about ditching mine. Just noticed a few days ago the sleeve that slides over the threaded rod on the passenger side is about 4 inches too short so it's not pressing agains the bushing, never noticed it b4. Also was wondering about the, I think it's called Track Bar, attached to the drivers side of the front axle. Was a PITA to get the new 3" lift springs on with that thing, and it's seriously got to limit travel, do people remove that? Or is it essential to have so the axle stays centered? <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
84 Ext. Cab Pickup.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6444 MB (Peak: 0.7649 MB) Data Comp: Off Server Time: 2026-06-07 05:58:08 UTC
