Catalytic Converter #877665 03/27/08 02:34 PM
cel36 Offline OP
Will a catalytic converter for a 95 Toyota 4 cylinder truck work on a 95 Toyota T100 6 cylinder truck?
Chad
Re: Catalytic Converter [Re: cel36] #877666 03/29/08 04:04 AM
shtkicker Offline
im pretty sure it doesnt matter with the cat.. but if its coming out you might as well go with a aftermarket
Re: Catalytic Converter [Re: shtkicker] #877667 05/01/08 11:27 PM
93montero_sr Offline
why after market? They are hard to pass smog with.
93 montero sr 3 inch body lift 31x11.50 super swamper ltb, 2 8inch 130 watt pro comp off road lights, 2 55w lights on the rear bumper, rear air locker, magnaflow exhaust muffler,superwinch manual hubs,15x8 black rock crawlers (steel)
Re: Catalytic Converter [Re: 93montero_sr] #877668 05/01/08 11:56 PM
hazy_daze Offline
Timely response <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/nana.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Catalytic Converter [Re: hazy_daze] #877669 05/02/08 06:58 AM
Only a month and a half late. <img src="/forums/images/graemlins/smile.gif" alt="" /> Better late then never <img src="/forums/images/graemlins/evil.gif" alt="" /> But i hardly ever look here.And hardly anyone post here.
Re: Catalytic Converter [Re: 93montero_sr] #877670 09/02/08 01:20 AM
Jeepeater Offline
Why aftermarket? Cost. I can get an aftermarket cat installed for 100 bucks for my 22re. From Toyota, the cat is 600 bucks. Ugh. People are stealing them like crazy around here too.... that doesn't help. Maybe I should eat the price of a new one and weld the SOB in there.
Re: Catalytic Converter [Re: Jeepeater] #877671 09/03/08 04:01 AM
Jim_Paget Offline
Welding won't do you any good unless you put a skid pan under it. We had two cut out in the same day in our parking lot at work. A battery powered sawzall can do the job in seconds, and I understand there is some other kind of tool that is even quicker.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Catalytic Converter [Re: Jim_Paget] #877672 09/08/08 12:53 PM
bombardj1 Offline
( A battery powered sawzall can do the job in seconds, and I understand there is some other kind of tool that is even quicker. )
A rife with a scope in quick, then you would own the battery powered sawzall, but you would need to buy a charger for it.
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Moderated by  4x4Wire, PHIL_
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6226 MB (Peak: 0.7006 MB) Data Comp: Off Server Time: 2026-06-17 11:58:17 UTC
