T-100 rear brakes locking #877688 03/27/08 06:03 PM
W
wizardz Offline OP
I have a problem with my truck and I'm wondering if anyone has experienced something similar or perhaps someone knows what the issue might be. In the morning or after the truck has rested, my rear brakes want to lock up. It seems to happen in all kinds of weather and will happen whether or not I use the handbrake. It appears to be only the right rear, but I'm not entirely sure. Several days ago the wheels remained locked even though I had taken my foot off of the brake. I attempted to pull away from the stop when I realized the truck wouldn't move. I applied the accelerator and heard something break free.
I plan on taking the rear wheels off this weekend to investigate.
<img src="/forums/images/graemlins/evil.gif" alt="" />
*95 T100, 4WD, EXTCAB, SR5, 5spd, 2.5 mm bored throttle body, Kumho Venture MT, Bilstein HD, TRD SC, URD Performance Upgrade Kit, 2" body lift, TRD headers coming soon
*06 Toyota Rav4 269HP 4wd V6
Amsoil in all
Re: T-100 rear brakes locking [Re: wizardz] #877689 03/27/08 09:23 PM
BamZipPow Offline
Sounds like some of yer brake components have some rust or build up on them. Yer wheel cylinder and springs are probably in need of a rebuild. Price out yer parts and git them ready. Don't fergit to purge the old stuff out and put new fluid in yer system. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: T-100 rear brakes locking [Re: BamZipPow] #877690 03/27/08 10:27 PM
J_Bird Offline
"BZP" is probably correct. I had the same symptoms, a long time ago. I had done some water crossings (1-2 foot)and got some water in the axle tube. The water in there would freeze something at night. In the morning I would have to put in gear and gas it to bust it loose. It worried me at first, till I figured out what it was. I drained the chunk, refilled and the problem was gone.
J-Bird
'95.5 T, SR5, Bone stock w/32x11.50's
'06 Sonata LX
Re: T-100 rear brakes locking [Re: J_Bird] #877691 03/27/08 11:31 PM
CJMT100 Offline
I have the same issue, came to the conclusion I need to replace the inner works of the drums as I already replaced everything else.
After theyheat it up it goes away right?
Re: T-100 rear brakes locking [Re: CJMT100] #877692 03/28/08 01:07 PM
W
wizardz Offline OP
Yep, after they heat up I no longer have the issue.
Amsoil in all
Re: T-100 rear brakes locking [Re: wizardz] #877693 03/31/08 03:02 AM
T100_4x4 Offline
my old man was telling me about this one time and wheel cylinder springs could be the cause like the guy above said.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6124 MB (Peak: 0.6824 MB) Data Comp: Off Server Time: 2026-06-07 03:14:11 UTC
