Blend Proportioning Valve #877857 03/28/08 04:03 PM
8
85Montero Offline OP
Was going to blow out my lines with compressed air while I'm redoing my brakes. Was wondering if the air would mess up my BPV between the mas. cylinder and back brakes.
Gen1
Thanks
Re: Blend Proportioning Valve [Re: 85Montero] #877858 03/28/08 05:50 PM
Probably not, but why not just take it loose?
Re: Blend Proportioning Valve [Re: 85Montero] #877859 03/28/08 07:08 PM
DirtDriver Offline
SNQ. Why blow out the lines? Why not bleed them clean?
1990 Monty LS 3.0 A/T LWB. KYB front shocks, OME rears and coils. 33x10.5 BFG Muds. 5.29, 2.85, RD110, RD46. 2 bouncys. Aisins. Monte Disco swaybar disconnects. GenII t-arms, idler arm, UCA's, V45W front brakes. 2in BL.
Re: Blend Proportioning Valve [Re: DirtDriver] #877860 03/28/08 08:03 PM
8
Don't want to take something loose I dont have to. The line to the back is already leaked empty as I had a back wheel cylinder go bad. So I replaced all the hardware in the back so the two rear hard lines were already removed and blown out. The old fluid looked like coffee.Just wondering...no biggie.
Re: Blend Proportioning Valve [Re: 85Montero] #877861 03/28/08 09:00 PM
I'd leave the lines loose from the new wheel cylinders and refill the master cylinder, letting gravity and some judicious pumping carry the fluid/air back closer to the bleeder (or pipe joint). Then I'd bleed from the master outward, bleeding the master at the flare nuts to the hard lines, then each wheel starting with the closest. This should get new fluid everywhere without blowing wet shop air into the lines (unless you have a drier). Coffee colored and clear is not that bad (except it's probably wet). Cloudy or opaque coffee with grounds is not good. Means rust in the lines, and it will never quit.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6060 MB (Peak: 0.6697 MB) Data Comp: Off Server Time: 2026-06-07 07:25:07 UTC
