4Runner Coils--OK?? #878122 03/29/08 11:35 PM
G
greg_mgm Offline OP
I just replaced the rear shocks and coils on my 91 4Runner. I installed Performance Products 1" progressive springs and Doetch Tech MV-12 shocks. There's a noticeable improvement in the ride, and it doesn't bottom out like it did before. My concern is how the top 4 coils are pressed against each other (on both sides) The ride height is perfect, and it drives very nice...so, any concerns with the coils? Here's a couple shots of the springs (vehicle unloaded)-
91 4Runner V6 Auto 4x4 Performance Products progressive rear springs, Doetsch Tech MV 12 shocks, Rancho 9000 front shocks.
Re: 4Runner Coils--OK?? [Re: greg_mgm] #878123 03/29/08 11:54 PM
4Crawler Offline
That is the nature of a progressive coil spring, the closely spaced coils are the soft ones and the wider spaced ones are stiffer. So the soft ones have compressed. Suppose as long as the rider quality is OK, then they are working like they are designed to. Maybe contact PP and ask them if that is normal for that application.
Re: 4Runner Coils--OK?? [Re: 4Crawler] #878124 03/30/08 01:43 AM
G
greg_mgm Offline OP
Thanks Roger. Ya, it rides very good, but I'll still call PP and ask 'em. I've just never seen coils compressed together like that on an unloaded vehicle. May be no problem, but thought I'd ask. Thanks.
Re: 4Runner Coils--OK?? [Re: greg_mgm] #878125 03/30/08 09:41 AM
Adam F Offline
Yes, that is how that particular coil spring is designed to be. Perfectly normal.
97 4R, stock, daily driver
Re: 4Runner Coils--OK?? [Re: Adam F] #878126 03/30/08 06:20 PM
Jake97T Offline
same as above, doesnt look like there is any chance they could bind up at full compression.
Re: 4Runner Coils--OK?? [Re: Jake97T] #878127 03/31/08 01:15 AM
G
greg_mgm Offline OP
No worries...I'm going to drive it...and off road it like it should be driven. Thanks for the replies.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6113 MB (Peak: 0.6814 MB) Data Comp: Off Server Time: 2026-06-07 06:00:19 UTC
