Re: gas tanks [Re: jaybur] #878138 04/05/08 04:44 PM
Lou Offline
..ehhh..mine just started leaking again. I did a repair last summer as here in Canada they say the recall is just about a nylon pipe they change on the pump module...but someone from Ste-Catherines Ontario got his changed for free last year. ...will try the "squeeky wheel" way again....
Re: gas tanks [Re: Lou] #878139 04/05/08 05:03 PM
Iron Offline
Defboy just got his changed and he's here in Edmonton, I talked to the guy at my dealership and I can get mine changed also, to bad it's not leaking!
08' Jeep Wrangler
64' Plymouth Sport Fury 383
58' Triumph TR-3A
Re: gas tanks [Re: Lou] #878140 04/06/08 05:08 PM
DEFBOY35 Offline
is it leaking at the tank or at the pump.
i had my pump fitting start leaking last year, and had fixed it. just last week i had my tank replaced under the american recall, i think it helped my situation that my truck originally came from down east were they use the salt. it was leaking at the tank seam, and as well at the fuel pump nylon fitting again!.
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: gas tanks [Re: DEFBOY35] #878141 04/07/08 04:22 AM
xjeepr Offline
Had the dealer here in Calgary run my VIN & since my Sporty was originally sold here it does'nt fall under the recall. Only recall that shows up for mine has something to do with the heater control. Also emailed Kia Canada asking about recalls & they said the same thing <img src="/forums/images/graemlins/frown.gif" alt="" />.
Guess on the upside...if it aint broke don't fix it <img src="/forums/images/graemlins/smile.gif" alt="" />.
xjeepr(Rob)
01 Sporty 4dr
1.4" 4crawler BL, 2.5" Upyourkia spacers with rear TJ coils, 29.5x11.5 SSRs on black DC-1s
Custom bumpers, rails & skid
www.go-greener.ca
Re: gas tanks [Re: xjeepr] #878142 04/13/08 09:35 PM
turtleskia Offline
if you replace the tank yourself, make sure you have the correct one. i had to replace the tank on my old sportage and was sold the wrong one. all the tanks are built the same on the first gen. but the internal baffles are different after 97, i ended up cutting the back half of the baffle. the baffle and the fuel pumps were changed after 97.
95 sportage, gone and severly missed.
94 camaro 5-speed v6 with a few addons.
girlfriends 93 s-10 4.3 soon to be lifted and made into a pre-runner
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.006s) Memory: 0.6135 MB (Peak: 0.6943 MB) Data Comp: Off Server Time: 2026-10-22 12:14:45 UTC
