Drive train locked up
#878267
03/31/08 12:40 AM
Hello all,
I was out 4 wheeling today and everything was fine. When I got back to the paved road, I moved the transfer case lever back to 4H, or tried to. I got into neutral and it's now stuck there. I can feel the clutch engage in any of the gears, but no drive... I had to get towed home. After I got home I got underneath and looked around. Both drive shafts are locked together (if I turn one the other turns also) -(so is the xfer case REALLY in neutral). I cannot move the xfer case shift lever no matter what I do. The trans will not/is not engaging for drive power. Any ideas?
Thenks - Dan
Re: Drive train locked up
[Re: DanWeisenstein]
#878268
03/31/08 03:51 AM
You just have to remove the t-case shifter handle, realign the rods with a large screwdriver and then replace your shifter sheet. It is a common problem. Remember, these things are 20 years old. They wear... http://www.izook.com/reviews/tcasefix/tcasefix.htmA new shifter sheet can be purchased from most of the Zook vendors. Zuks offroad also has them in brass - a part that you will probably never wear out again.
Bill ---------------------------- God Forgives, Rocks Don't...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5862 MB (Peak: 0.6342 MB) Data Comp: Off Server Time: 2026-06-07 07:25:39 UTCValid HTML 5 and Valid CSS
