Ok Guys I need HELP!! #878611 04/02/08 12:44 AM
TheCEO Offline OP
I have a 95 1/2 Ton 2 wheel Drive, I know. Toyota T100. I've been looking everywhere for a Rear disc Brake conversion kit. Cant find anything. As Im sure you know my Truck eats up the front rotors like crazy. ANYONE...Please!!!
Re: Ok Guys I need HELP!! [Re: TheCEO] #878612 04/02/08 04:22 AM
Jake97T Offline
look for conversions for the early mini Toyota 4x4 trucks (86-95) they should work for you as well.
Re: Ok Guys I need HELP!! [Re: TheCEO] #878613 04/02/08 05:09 AM
BamZipPow Offline
Sounds like yer back brakes aren't adjusted correctly and maybe not even properly bled out. It could even be yer load proportioning valve might be mis-adjusted as well. <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Ok Guys I need HELP!! [Re: TheCEO] #878614 04/02/08 11:53 AM
foxtrapper Offline
Eating rotors or pads? Brakes otherwise working right?
Hard semi-metalic pads will eat rotors comparatively quickly. Soft metal rotors (aka cheap rotors) go even faster.
If the brakes are unbalanced hydraulically, you can end up working the fronts much harder than the rears. This will not be fixed by going to rear rotors. In fact generally this conversion requires an aftermarket adjuster to get the front to rear balance correct.
All by themselves, installing rear discs will do nothing to improve the fronts rotor consumption.
'97 T-100 SR5
Re: Ok Guys I need HELP!! [Re: foxtrapper] #878615 04/02/08 08:23 PM
Jake97T Offline
agree with the above, im using HAWK pads, Brembo rotors, and 35" tires with no unusual break ware.
Re: Ok Guys I need HELP!! [Re: TheCEO] #878616 04/03/08 05:54 PM
speedlever Offline
snip..As Im sure you know my Truck eats up the front rotors like crazy. ANYONE...Please!!!
Is this unique to the 2wd T's? I have over 120k on my 4wd T100 and am still on the original front brakes. Had to do the rear drums at 90k due to axle bearing seals leaking and the shop messing up the brakes.
--speedy
White '98 T100 SR5 4x4 ExCab Auto - wrecked.
2008 Honda Ridgeline RTS replaced the T100.
Re: Ok Guys I need HELP!! [Re: Jake97T] #878617 04/04/08 04:12 AM
G
GregZ Offline
I have a 1998 4WD T100 that just hit 80,000 miles, and I had my first brake work ever done on it 2 weeks ago. New front pads, rotors resurfaced, and nothing needed on the rear drum brakes.
Re: Ok Guys I need HELP!! [Re: GregZ] #878618 04/05/08 09:12 PM
TheCEO Offline OP
The 2 wheel drives, well all the folks that I know. Have the same problem. I use it for work and I am carring weight. Thanks for the imput..came to the right place smile
Re: Ok Guys I need HELP!! [Re: TheCEO] #878619 04/06/08 04:45 AM
CJMT100 Offline
You need better pads and rotors imho. I use hawk LTS and brembo rotors and no issues yet.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6247 MB (Peak: 0.7112 MB) Data Comp: Off Server Time: 2026-10-21 20:44:03 UTC
