Idiot lights on after cleaning engine. #82305 07/05/02 09:56 PM
Josh Offline OP
I cleaned my engine yesterday around 8 AM and left the truck setting to dry all day. I got in around 5:15 last night and noticed I had my A/T Oil Temp light on, as well as the battery light, and the light that comes on when the parking brake is on. What should I check? At first, I thought it was just wet connectors, but after setting all day in neer 100 degree heat, they are still on.
Josh
01 Chevy 2500HD: 6.0L gas 4x4 crew cab
in search of the next trail rig
Re: Idiot lights on after cleaning engine. #82306 07/05/02 10:00 PM
code33 Offline
Hopefully, it's just a short...
But a the battery light along with the parking brake dummy lights indicate a bad alternator.
If I get the motor wet, I usually start it up right away to warm it up so the water evaps faster.
Classifieds & Suzuki Moderator
Re: Idiot lights on after cleaning engine. #82307 07/05/02 10:04 PM
Josh Offline OP
Bad alt. you say? I have been having some starting troubles lately.
Josh
Re: Idiot lights on after cleaning engine. #82308 07/05/02 10:22 PM
Did you cover all electrical parts with plastic bags before you cleaned it?
Re: Idiot lights on after cleaning engine. #82309 07/05/02 10:30 PM
Josh Offline OP
No, I never have. I guess that is what I get for letting my dad use the hose.
Josh
Re: Idiot lights on after cleaning engine. #82310 07/06/02 12:14 AM
Sherpa Offline
I wash the engine every time I handwash Sherpa. I use a mild to moderately focused spray pattern that doesn't blast the engine. I usually start it either right after I rinse it or right before, and leave it running while I spray it off.
Don't wait too long between starting the engine and getting it wet... you don't want it to heat up so much that cold water might make it crack!
-Scott
1997 SR5 5-Spd. TRD Supercharger, URD Supercharger Performance Kit, "Bamachem Designed" 2.5" suspension lift, 265/75R16 Bridgestone Dueller Revos, Airbox Mod, Amsoil: (Air Filter plus engine, diff, x-fer case, + tranny oils)
Re: Idiot lights on after cleaning engine. #82311 07/06/02 12:37 AM
code33 Offline
What are the characteristics of the starting problem?
Could be that the alt. was going bad and the water just pushed it to the end. I did that on a Corolla once.
Oh, I don't know about the AT temp light, though. Does that come on right at startup or come on down the road?
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Josh:
<strong>Bad alt. you say? I have been having some starting troubles lately.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">
Re: Idiot lights on after cleaning engine. #82312 07/06/02 01:45 AM
Josh Offline OP
The start problem I think is just a bad battery cable. The AT Temp light comes on as soon as I start it though.
Josh
PHP: 7.4.33 Page Time: 0.010s Queries: 14 (0.006s) Memory: 0.6188 MB (Peak: 0.6958 MB) Data Comp: Off Server Time: 2026-11-01 12:15:43 UTC
