fuel system #879232 04/06/08 03:12 PM
P
poppy1 Offline OP
Hi Gang
Need some help with the fuel system on my 00 sportage I replaced the tank with a new tank from the dealer in Bangor Me. repaired the return line connector on the tank unit checked all the lines for leaks new gas cap but still no pressure in the tank the dealer and a tank repair shop here are telling me the tank has to have pressure to stop the DTC light from throwing trouble codes such as system running lean any information you can give me would be great as i dont know what else to try.
Thanks Poppy1
retired 18wheeler
Re: fuel system [Re: poppy1] #879233 04/06/08 05:10 PM
DEFBOY35 Offline
how is the seal between the tank and the fuel pump?
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: fuel system [Re: DEFBOY35] #879234 04/06/08 09:58 PM
P
poppy1 Offline OP
we had it out on thursday seal looks good and there is no sign of leaking around it
retired 18wheeler
Re: fuel system [Re: poppy1] #879235 04/07/08 01:57 AM
Iron Offline
Is the tank full? Could be you have a hole somewhere on the top part of the tank, even the seam!
08' Jeep Wrangler
64' Plymouth Sport Fury 383
58' Triumph TR-3A
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5998 MB (Peak: 0.6551 MB) Data Comp: Off Server Time: 2026-06-22 11:20:04 UTC
