Using a 3.4 HT crate engine #879933 04/09/08 02:41 PM
tomjarz Offline OP
Has anyone installed the 3.4 HT crate engine in their 2.8 trooper? Just wondering< I read threads on this sight before but the SEARCH feature has somthing to be desired and I can't locate that thread. I bought a 1990 trooper with a 2.8 and auto tranny. The engine is siezed so instead of a rebuild Iwas going to replace it.
I know on the 3.4 HT I need change the timming cover and have my intake bored for a 4.3 thottle body and probably have a custom 2.5" exhaust welded on from the "Y" pipe back.
Are threr any other issues, the disclaimer for the 3.4HT is that it is for carbureted use only. The stock 2.8 injectors are too small, but the 4.3 mod should work well, right?
Thanks again <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Using a 3.4 HT crate engine [Re: tomjarz] #879934 04/09/08 07:18 PM
Van Offline
Start by reading this thread....
A SHORTER LINK
Search.... Isuzu forum... +3.4... in subject.... newer than 5 years
I know, reading is boring... but hey, it increases your knowledge (until your brain cells get overloaded). <img src="/forums/images/graemlins/notooth.gif" alt="" />
HTH
Van <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
'94 Isuzu Pickup, 4x4
NEVER give up...
Re: Using a 3.4 HT crate engine [Re: tomjarz] #879935 04/20/08 02:15 PM
HondaGuy Offline
The fuel delivery statement is for emissions only. the other option instead of the 4.3 throttle body is the Holley TB. it has adjustable fuel pressure regulator as well as higher flow injectors. it is also larger bore. A bit pricey though...
Re: Using a 3.4 HT crate engine [Re: tomjarz] #879936 06/16/08 06:01 AM
Nick Muzzio Offline
I have the 3.4 crate engine (not sure if it's the HT though) and I am using the 4.3 with the 4.3 injectors. Even though the injectors are bigger the computer still uses the 02 sensor data to put more or less fuel in. just the 4.3L injectors will never be the weakest part of the chain anymore. I also have the 2.5" exhaust now from the y pipe. Sounds a lot better!
91 Trooper LS, 5 Speed Manual
3.4L Engine w/4.3L Throttle Body
Snorkel, 31" Pro Comp MT Tires, 2"lift,
ProComp ES9000 shocks and steering stabilizer
http://members.cardomain.com/sun_thief
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6023 MB (Peak: 0.6591 MB) Data Comp: Off Server Time: 2026-06-07 06:55:25 UTC
